Find a 2x2 Matrix with given EigenValues
  • Thread starter Thread starter Jtechguy21
    Eigenvalues Matrix
5 replies · 7K views
Jtechguy21
Find a 2X2 matrix that has all non-zero entries where 3 is an eigenvalue
well since the 2x2 matrix cannot be triangular, it makes things harder for me.
I have no idea where to start. I am not given any eigenvectors either.
It seems like a simple problem, but I've been stuck on it for a while.
If I did not have the zero entries restriction i would have selected 2x2 matrix
A= {{3,0}{0,3}}τ
Can Someone point me in the right direction?
The eigenvalue equation is for the 2X2 matrix, if written as a system of homogeneous equations, will have a solution if the determinant of the matrix of coefficients is zero. So we have the equation ## \lambda^2-(a+d)\lambda+ad-bc=0## where ## \lambda ## is the given eigenvalue and a,b,c and d are the unknown matrix entries. So we have one equation for four unknowns which means this is an under-determined system. So there are an infinite number of 2X2 matrices with a given eigenvalue. Just choose three of the entries arbitrarily and determine the fourth via the above equation.
thanks for your help Shyan Using that system I was able to solve my problem :)
First, while you said that "3 is an eigenvalue", you did NOT say that it was the only eigenvalue, a double eigenvalue. Even assuming that there are an infinite number of such 2 by 2 matrices. One way to find one is to start with the diagonal matrix [tex]M= \begin{bmatrix}3 & 0 \\ 0 & 3\end{bmatrix}[/tex]. Now, for any invertible matrix, A, [itex]AMA^{-1}[/itex] will have the same eigenvalues so you only need to choose A so that has no 0 entries.
Completely different solutions can be found by starting, not with a diagonal matrix, but with the "Jordan Normal Form", [tex]M= \begin{bmatrix}3 & 1 \\ 0 & 3\end{bmatrix}[/tex]
If [itex]M[/itex] is a multiple of the identity, then it commutes with [itex]A[/itex] so that [itex]AMA^{-1} = MAA^{-1} = M[/itex], which has zero entries.
This is necessary if 3 is to be a repeated eigenvalue, but the question doesn't require that.
