Find A Counter-Example to This
  • Level: Graduate
  • Thread starter Thread starter Atran
4 replies · 2K views · last reply
Atran
Hi!
Say p(x) is the product of the first x odd prime numbers (e.g. p(4)=3*5*7*11) and i is at least one. Then consider:
1 < p(x) ± 2*i < (p(x+1)/p(x))2
My hypothesis is that the above formula, obeying the restrictions, always produces a prime number.
For example if x=3 and i=13, then p(3)-2*13=79. 79 is bigger than 1 and smaller than 112, therefore it's a prime number.
I'm not a python programmer, but this code yields prime numbers using the above formula:
Code:
from math import ceil
def is_prime(number):
    if(number < 2):
        return False
    i = 2
    while i <= ceil(number**0.5):
        if(number%i == 0):
            return False
        i = i + 1
    return True
def f(number_of_primes):
    flag = True
    prime_product = 1
    prime_array = []
    n, i = 3, 0
    while i < number_of_primes:
        if(is_prime(n) == True):
            prime_product = prime_product * n
            prime_array.append(n)
            i = i + 1
        n = n + 1
    while True:
            largest_prime = n
            break
        n = n + 1
    i = 1
    while True:
        for x in range(len(prime_array)):
            if(i%prime_array[x] == 0):
                flag = False
                break
        if flag == False:
            flag = True
            i = i + 1
            continue
        n = prime_product - 2*i
        if n <= 1:
            break
        if n < largest_prime**2:
            if is_prime(n) == False:
                print("NOT : ", n, " : ", i)
                break
            else:
                print("NMB : ", n, " : ", i)
        i = i + 1
def g(number_of_primes):
    flag = True
    prime_product = 1
    prime_array = []
    n, i = 3, 0
            i = i + 1
        n = n + 1
    while True:
            largest_prime = n
            break
        n = n + 1
    i = 1
    while True:
                flag = False
                break
        if flag == False:
            flag = True
            i = i + 1
            continue
        n = prime_product + 2*i
                break
            else:
        else:
            break
        i = i + 1
x = 4 # Enter a non-negative integer
f(x)
print("- - - - -")
g(x)
Scroll down and assign a non-negative integer to x in the code and run it. If the program detects a non-prime then it should output "NOT" followed by the generated number. If the generated number is a prime, then it outputs "NMB". The second number after the second colon is the value of i. So the above example would be displayed as: "NMB : 79 : 13" (excluding the double quotes)
Thanks for help.
Mathematics news on Phys.org
I want somebody to prove this wrong, by finding a counter example.
And I'm really sorry, I forgot to mention that i must not be divisible by any of the primes found in the product p(x).
So again,
where p(x) is the product of the first x odd prime numbers, and i is a positive integer not divisible by any prime in the product p(x).
Example: p(4) - 2*514 = 127.
514 is positive and not divisible by 3, 5, 7, or 11. And 127 is less than 169, so according to the conjecture 127 should be a prime, and it is.
Your best strategy here would be to let the program find the counter example by finding a list of primes for input and then running it thru its paces. Also if you could find a related program that can check for primeness of a number you could incorporate it into the mix.
So again,
It's a true conjecture. Here's a proof:
First, we note that since ##p(x)## is not divisible by ##2## and ##2i## is divisible by ##2##, then ##p(x) - 2i## is not divisible by ##2##.
Second, if ##p## is an odd prime occurring in the product of ##p(x)##, then ##p## divides ##p(x)## and ##p## does not divide ##2i##, thus ##p## does not divide ##p(x) - 2i##.
So we deduce that if ##p## is any prime dividing ##p(x)-2i##, then ##p## cannot occur in ##p(x)##. Thus ##p\geq p(x+1)/p(x)##.
So, assume that ##p(x) - 2i## is composite, then there are there are two prime numbers ##p## and ##q## that divide ##p(x) - 2i##. Thus we have ##pq\leq p(x)-2i##. But we also have that ##p\geq p(x+1)/p(x)## and ##q\geq p(x+1)/p(x)##. Thus ##pq\geq (p(x+1)/p(x))^2##. So we see that
[tex](p(x+1)/p(x))^2\leq pq\leq p(x)-2i < (p(x+1)/p(x))^2[/tex]
which is a contradiction.
