Find a vector such that directional derivative is zero
5 replies · 29K views
username12345
Let [tex]f (x, y) = e^x^2 + 3e^y[/tex] . At the point (0, 1) find:
(a) a vector u such that the directional derivative [tex]D_u f[/tex] is maximum and write down this maximum value,
(b) a vector v such that [tex]D_v f = 0[/tex]
grad f / directional derivative formula
I can find part (a), simply calculate the gradient vector, but part (b) I don't know what to do. The answer given is:
(b) Dv f is zero when v is tangent to the level curve passing through (0, 1), i.e. when v = i
(or some multiple of this).
I don't understand what this means.
well, you probbably know that:
[tex]D_uf=grad{f}*u=|grad{f}||u|cos \theta=|grad{f}|[/tex]
you only need to fill in the details. theta is the angle between grad{f} and u.
(b) a vector v such that [tex]D_v f[/tex]
You mean [tex]D_v f= 0[/tex]?
Along a level curve, the function is a constant. (That's what "level curve" means!). That's why the derivative in that direction is 0. You can also do this by using the formula for derivative in the direction of unit vector v: [itex]D_v f= \nabla f\cdot v[/itex]. The dot product of those two vectors will be 0 when they are perpendicular. Of course, a unit vector that makes angle [itex]\theta[/itex] with the x-axis is [itex]cos(\theta)\vec{i}+ sin(\theta)\vec{j}[/itex] so you can also say that the derivative in the direction making angle [itex]\theta[/itex] with the x-axis is [itex]cos(\theta) \partial f/\partial x+ sin(\theta)\partial f/\partial y[/itex].
It shouldn't be too hard to see that if you are standing on a mountain looking up the steepest direction, the steepest direction down is right behind you and the trail around the mountain, the level curve, is to your side- at right angles to the "steepest" way.
The gradient is always perpendicular to a level curve.
The explanation above is good.
So, if say the gradient vector was i + 2j, then a vector such that Dv f = 0 would be +- (2i - j) ?
Ok, got it, thanks.
