Find angle (Projectile Motions)
  • Thread starter Stingarov
  • Tags
    Angle
In summary, the ball was thrown from a height of 1.86 meters and landed at a distance of 40.4 meters from the thrower. The angle of projection was 59.4 degrees.
Stingarov
Alright so I thought I understood this well.
I'll give an example of how I solve for range and such with the given information:
A ball is thrown from a height of 1.86 m, at a speed of 21 m/s and at an angle of elevation of 59.4o. How far from the person who threw it does the ball land?
Range: Vxt
Vx: Vcos Theta
Vy: V sin Theta
The method in which I solve for t goes as follows:
Vy = 21 * sin59.4
Vy = 18.07
Maximum Height: v²= 2a(s) +existing height of 1.86
Maximum height: 18.07² /2(9.8) = s -> 16.66 + 1.86 = 18.52m
Total time: Time down + Time Up
s + 1.86 = 1/2at² + s = 1/2at²
18.52*2 / 9.8 = t² + 16.66 * 2/9.8 = t²
1.94 + 1.84 = 3.78s
R = V cos Theta * t
R = ~40.4 m
The problem I encounter is simply that I do not know how, using this method, or by any other really, to compute the angle or initial velocity if Total time is not a given already.
Say the equation was rearranged and said:
A person threw the ball at an initial rate of 21 m/s from a height 1.86. It hit the ground at 40.4m. What was the angle of projection?
Can anyone help show me how to work these backwards? Would be highly appreciated.
v=21
h=1.86
(a means angle)
Vx=V*cos(a)
Vy=V*sin(a)
when the ball hit ground ,x=40.4,y=0.
put it into the equation andrevdh gave to you:
Vx*t=x
[tex]y = v_{yo}t - \frac{1}{2}gt^2[/tex]
you may solve it,though it may difficult in maths.
From now on,I advise you to learn more algbra.It is important in physics.
For the given equation y = ...
y will not be zero when the ball lands!
Oh,Yes,I am so sorry!
It should add h in.
It seems you are trying to solve a though problem.
See the section :"Angle θ required to hit coordinate (x,y)" in Wikipedia:
http://en.wikipedia.org/wiki/Trajectory_of_a_projectile"
Like this y=h+Vy*t-(1/2)*g*t*t
close, more like
[tex]y = y_o + v_{yo}t - \frac{1}{2}gt^2[/tex]
or if you take the launching point as (0,0) y = - 1.86
Ah alright, thanks
1. What is projectile motion?
Projectile motion is the motion of an object through the air under the influence of gravity. It follows a curved path called a parabola and is influenced by both the initial velocity and the angle at which the object is launched.
2. How do you find the angle in projectile motion?
To find the angle in projectile motion, you can use the formula θ = tan-1(vy/vx), where θ is the angle, vy is the vertical component of the initial velocity, and vx is the horizontal component of the initial velocity.
3. What is the optimal angle for maximum distance in projectile motion?
The optimal angle for maximum distance in projectile motion is 45 degrees. This is because at this angle, the vertical and horizontal components of the initial velocity are equal, resulting in the longest possible range.
4. How does air resistance affect the angle in projectile motion?
Air resistance can affect the angle in projectile motion by altering the trajectory of the object. In the presence of air resistance, the optimal angle for maximum distance may vary from 45 degrees and may require a higher or lower angle depending on the specific conditions.
5. Can the angle in projectile motion be negative?
Yes, the angle in projectile motion can be negative. This typically occurs when the object is launched downwards, such as throwing a ball off a cliff. In this case, the angle would be measured as negative relative to the horizontal axis.
