Find angles between two rope and the ceiling
  • Thread starter Thread starter seanster1324
    Angles Rope
7 replies · 3K views
seanster1324
***Excuse the pluralization error in the title***
I attached a picture below...
sin^2(theta)+cos^2(theta)=1
a^2+b^2=c^2
Vector properties
Trig identities
I am familiar with trig identities and vector properties, but I can't get anywhere with this. I tried using the 697N weight as the y-component vector for either side, but that didn't work.
a^2+b^2=c^2
Vector properties
Trig identities
resolve each tension into vertical and horizontal components.
The horizontal components have to balance each other,
The vertical components together support the mass.
I understand that part. The part I don't understand is how to separate each vector into its components. I only have the magnitude with no given angles. Looking at the hint, I need to play around with some trig. But I can't see how to incorporate the identity it hints at.
And I can't use 697N as the shared vertical component, right? Because that would make this much easier, but it did not work for me.
You have two unknowns, theta 1 and theta 2
Vertical considerations will give one equation involving them
Horizontal considerations will give a second equation connecting them
Two equations in two unknowns should mean a simultaneous equations solution is possible.
EDIT: you could also use the cosine rule to find the angles.
Ah, I see what you mean. Thank you so much!
Witch cosine rule? The Law of Cosines?
