Find capacitance from time, power, and voltage
The discussion revolves around calculating capacitance for a flashlight that uses 6.0J of energy in 1.8ms at 200V. Initially, the user calculated the power as 3333W and derived a charge of 0.03 coulombs, leading to a capacitance of 1.5E-4 farads, which was incorrect. A suggestion to use the energy formula U = 0.5QV revealed that the correct charge should be 0.06 coulombs, doubling the previous calculation. The user realized the mistake stemmed from assuming constant voltage and current during discharge, which does not occur in real capacitive situations. The discussion highlights the importance of understanding energy storage in capacitors and the effects of exponential decay in electrical circuits.
ikjadoon
A flashlight uses 6.0J in 1.8ms (0.0018 seconds). First question: find the power. Got it: 3333W (3.3E3 with two sig figs, which is the accepted answer in the online system).
The real problem: find the capacitance if the flashlight uses 200V.
Power = Energy used / time
Capacitance = charge / voltage
Power = Current * voltage
Current = delta charge / delta time
OK, P = 3333W and V = 200V. Divide to get current, which is 16.67 amps.
16.67 amps and it took 0.0018 seconds to do so. Thus, the change in charge is .03 coulombs via the last equation listed.
Now we have both charge (.03) and voltage (200V).
The capacitance is just the quotient, charge / voltage. I get 1.5 * 10^-4 farads (1.5E-4 F). I have done it at least four times now. No dice. I tried rounding at different times, but I tried 1.5E-4 F and 1.4E-4 F and neither worked. The online system wants 2 significant figures and the appropriate units. I've got two and capacitance is definitely in farads!
What unfortunate mistake am I making?
~Ibrahim~
Have you considered directly equating the energy delivered to that stored on a capacitor?
Energy delivered to that stored on the capacitor...the U = .5QV formula!
No: I just tried it and it worked!
This time, instead, I got .06 coulombs as the charge, twice the charge compared to my previous attempt.
I completely forgot about that one. But, out of curiosity, why did my initial approach not work? It's bugging me because I can't find the mistake I made or the assumption I took that wasn't valid?
Thank you so much for your help, either way! :D
~Ibrahim~
EDIT: Oh, wait! Is it because the initial charge I calculated was just the charge on one plate?! And the total charge is actually the charge of BOTH plates?
I think the problem lies in assuming that the voltage and current were constant over the discharge. This will never happen in a real capacitive situation; everything follows exponential decay curves. So the only thing you could really count on from the given data is the total energy delivered and the initial voltage.
Ohhhhh, OK, right, right, right. We just went over those exponential curves today. That makes sense: it wasn't 16.67 amps at the very beginning.
Whew...all right; thank you!
~Ibrahim~
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
