Find coefficient of kinetic friction between a bullet and a pendulum
The problem involves a bullet colliding with a block suspended from a pendulum, where the bullet embeds itself into the block. The scenario requires finding the coefficient of kinetic friction between the bullet and the block after the collision, with specific parameters such as the masses of the bullet and block, the distance the bullet penetrates, and the angle of swing.
  • Mixed
  • Participants discuss using momentum and energy conservation to find the initial velocity of the bullet and explore the implications of forces acting on the bullet after the collision. There are attempts to apply various equations of motion and consider the effects of the angle of swing.
Some participants have provided feedback on calculations, particularly regarding unit consistency and the interpretation of forces involved. There is an ongoing exploration of the relationship between the normal force and the coefficient of kinetic friction, with some questioning the assumptions made about the forces at play.
Participants note the lack of specific information about the materials involved and the forces that would affect the normal force during the bullet's embedding process. There is also mention of the assumption that the bullet comes to rest quickly within the block, which may influence the analysis.
jreelawg
A bullet collides and embeds itself into a block hanging from a rope. The block and embedded bullet swing out to an angle of 10 degrees.
If the bullet plows 2 cm into the block before stopping, what is the coefficient of kinetic friction between the block and the bullet?
bullet has mass of .1 kg
block on pendulum of length 1 m has mass of 5 kg
momentum conservation, energy conservation, Newtons laws
I found the initial velocity of the bullet, 273.386 m/s^2, using momentum and energy conservation.
Thought maybe I could use, vf^2 = vi^2 + 2ax, which I guess tells me that the bullet after collision had an acceleration in the x direction of -1,868,500 m/s^2 with respect to the frame of reference of the pendulum+embedded bullet.
I thought maybe I would then use F=ma.
I think your on the right track.
Would'nt it just be from where you left off:
Ffriction = ma
Ff = ma
UN = ma
Umg = ma
U = ma/mg
U = a/g
Also make sure to take the 10 degree into consideration and i think your good then.
Wrong units - should be m/s. And I get rather less than 273m/s. Please show your working to this point.
I accidentally used .01 instead of .1 for mass of bullet in my calculation.
Here is what I have. I'm especially unsure about the validity of the last part.
v1 = velocity immediately after collision
v0 = initial velocity of bullet
mp = mass of pendulum = 5 kg
mb = mass of bullet = 0.1 kg
y = delta Y = 1 - cos(10 degrees)
momentum conservation:
mb*V0 = (mb + mp)*v1
v0 = (mb + mp)(v1)/mb
energy conservation of swing:
1/2(mb + mp)*v1^2 = (mp + mb)*yg
v1 = (2yg)^(1/2)
=> v0 = (mb + mp) (2yg)^(1/2) / mb
=((.1 + 5) (2*(1-cos(10))*9.8)^(1/2) )/0.1
= 27.8297 m/s
Acceleration of bullet after collision:
0 = 27.8297^2 + 2*a*(0.02)
a = -(27.8297^2) / 0.04)
= -19326.3 m/s^2
Force:
Fnet on bullet = Fk = -9.8 * 0.1 * Uk = -19326.3 * 0.1
Uk = 1972.07
My thoughts:
I don't think the last part is right. I would think that the main "normal" force affecting the friction would be the block squeezing the bullet as it embeds itself into the block. The coefficient of kinetic friction I would think would be a constant determined by the two materials. But this problem doesn't lend any information about either the force which would squeeze the bullet or specific materials.
Could this be solved using the work kinetic energy theorem?
So kinetic energy is lost to thermal energy.
1/2(mb)V0^2 - 1/2(mb + mp)V1^2 = Eth ?
= 37.9634 J = fk (.02) = n * Uk
uk = (37.9634/.02)/n = 1898.17/n
So is n really just the (mb)g?
jreelawg said:
= 27.8297 m/s
Agreed. (Though this is making the simplifying assumption that the bullet comes to rest so quickly within the block that most of the swing is with the bullet and block moving as one. Tricky question otherwise.)
Again, I agree. You can calculate the retardant force on the bullet, but that still doesn't tell you the coefficient of friction.
Ok. Thanks haruspex. I guess I'll put this problem to rest for now.
