Find derivative of ((rdot^2) + ((thetadot * r)^2))^(1/2)
  • Thread starter Thread starter toastie
    Derivative
12 replies · 4K views
toastie
i have rdot which is equal to the dr/dt and I have thetadot which is equal to d(theta)/dt.
I need to find the derivative of ((rdot^2)+((thetadot*r)^2))^(1/2)
I believe that I am just making errors in my derivation, but I keep getting [2(dr^2/d^2t)+2thetadot*r+2((dtheta^2)/dt)*r]/((rdot^2)+((thetadot*r)^2))^(1/2)
Using the chainrule.
[tex] \frac{d \dot{r}^2}{dt}=\frac{d \dot{r}^2}{d \dot{r}} \frac{d \dot{r}}{dt}=2 \dot{r} \frac{d \dot{r}}{dt}=2\dot{r}\ddot{r}[/tex]
okay. is there any other mistakes in my derivation now:
[2(dr/dt)*(dr^2/d^2t)+2thetadot*r+2((dtheta^2)/dt)*r]/((rdot^2)+((thetadot*r)^2))^(1/2)
I did the first term (without the root) for you so you could see how to use the chain rule. All you have done now is use my answer and replace the first term of your answer with mine. This really won't help you a lot. You used the chain rule incorrectly for the other terms as well. Use my example to get the correct answers and post your steps here. Don't forget that theta and r are functions of t so the chain rule needs to be applied on every term.
okay. I have used the chain rule and got:
[2*rdot*((dr^2)/d^2t) + 2*rdot*thetadot + 2*((dtheta^2)/d^2t)*r]/((rdot^2)+((thetadot*r)^2))^(1/2)
It's almost correct. First off [itex](1\sqrt{x})'=1/(2\sqrt{x})[/itex]. Secondly you took the derivative of [tex]2\dot{\theta}r[/tex]. You should take the derivative of [tex](\dot{\theta}r)^2[/tex].
i thought the derivative of (theta*r)^2 was = 2*thetadot*dr/dt + 2*((dtheta^2)/d^2t)*r
thus i got:
[rdot*((dr^2)/d^2t) + rdot*thetadot + ((dthetadot^2)/d^2t)*r]/((rdot^2)+((thetadot*r)^2))^(1/2)
That's basically saying dx^2/dx=2. Do you see where you went wrong now? You applied the product rule correctly after wards, the problem lies with the first step.
okay so should (theta*r)^2 be 2*thetadot*((dthetadot^2)/dt)*r^2 + 2*(thetadot^2)*dr/dt ?
This part is wrong.
I am not sure which chain rule "method" you were taught. But try to go back to basics and use that method step by step also writer as r(t) and theta as theta(t). This should prevent you from making mistakes. Secondly show the steps instead of just showing the final answer and asking whether it is right or not.
okay I begain with theta^2 times r^2 because it is the samething as (theta*r)^2. So using the product rule I get 2*r^2*theta*d(theta)/dt + 2*(theta^2)*r*dr/dt.
If you replace theta by thetadot and thetadot by thetadotdot you have the correct answer. I guess that was a typo?
