Find Min Surface Area: Absolute Min & Max Homework
  • Thread starter Thread starter Michele Nunes
    Absolute Max
The discussion focuses on finding the angle θ that minimizes the surface area S of a honeycomb cell, defined by the equation S = 6hs + (3s²/2)((√3 - cosθ)/sinθ). The derivative of the equation simplifies to (1 - √3cosθ)/sin²θ, leading to the critical point θ = cos⁻¹(1/√3). This value corresponds to the minimum surface area, confirming that the book's answer of θ = (√3)/3 is indeed correct, as both expressions are equivalent.
  • Understanding of calculus, specifically differentiation
  • Familiarity with trigonometric functions and their properties
  • Knowledge of optimization techniques in mathematical contexts
  • Basic comprehension of geometric concepts related to surface area
  • Study advanced calculus techniques for optimization problems
  • Explore trigonometric identities and their applications in calculus
  • Learn about geometric properties of polyhedra and their surface areas
  • Investigate numerical methods for solving optimization problems
Students in mathematics, particularly those studying calculus and optimization, as well as educators looking for examples of real-world applications of trigonometry and geometry.
Michele Nunes
The surface area of a cell in a honeycomb is S = 6hs + (3s2/2)((√3 - cosθ)/sinθ) where h and s are positive constants and θ is the angle at which the upper faces meet the altitude of the cell. Find the angle θ (π/6 ≤ θ ≤ π/2) that minimizes the surface area S.
Okay so first I took the derivative of the equation and the (3s2/2) isn't relevant since there's no θ involved so I'm going to disregard that part. Once simplified, on the numerator I obtained (1 - √3cosθ) and on the denominator just sin2θ but all the thetas that would make the denominator = 0 are not in the given domain of theta so then I focused on the numerator. The theta that would make the numerator = 0 is cos-1(1/√3) which should end up being the theta that gives the minimum value for the surface area, however the back of the book says theta should = (√3)/3 and I'm not sure where they got that value from.
If you mean that the book says ##\large \theta = \cos^{-1}\left(\frac {\sqrt 3}{3}\right)##, then it is the same as ##\large \theta = \cos^{-1}\left(\frac {1}{\sqrt 3}\right)##! Your answer is correct! :)
\frac{1}{\sqrt{x}} = \frac{1}{\sqrt{x}} \times \frac{\sqrt{x}}{\sqrt{x}} = \frac{\sqrt{x}}{x}
