Find out polarity of device for using ac-dc adapter
The discussion focuses on determining the polarity of the input for the Edirol R-09HR High-Resolution WAVE/MP3 Recorder when using an AC-DC adapter. Users are advised to measure the battery holder connections to identify the polarity, as the device lacks clear markings. It operates on two NiMH AA cells, requiring approximately 4 volts, and the original Roland AC adapter is recommended to avoid potential damage to the device. The user manual explicitly states that the unit cannot recharge NiMH batteries, emphasizing the necessity of using the proper adapter.
  • Understanding of AC-DC adapter specifications
  • Knowledge of battery polarity and connections
  • Familiarity with measuring voltage and polarity using a multimeter
  • Basic comprehension of the Edirol R-09HR specifications and user manual
  • Research how to measure battery polarity using a multimeter
  • Learn about the specifications and features of the Edirol R-09HR
  • Investigate the importance of using manufacturer-recommended AC adapters
  • Explore the implications of using non-standard charging methods for NiMH batteries
Audio engineers, musicians, and anyone using the Edirol R-09HR who needs to understand power requirements and adapter specifications.
aspfun
I have a audio recorder (Edirol R-09HR High-Resolution WAVE/MP3 Recorder) need to use ac-dc adapter.
There is no any marker to tell me polarity of input in this device.
(I check the adapter from amazon.com for this device which I do not have, there is no marker as well)
I have a Radio-Shack ac-dc adapter which I can adjust polarity.
The porblem is how to find out this audio recorder input polarity, that is, is pin "+" or "-"?
It runs off battery power, so remove the battery and measure to find out which side of the battery holder connects to the outer side of the input plug. This will tell you the polarity.
It can use two NiMH AA cells, so the supplied AC adaptor would have delivered about 4 volts, but it may have included circuitry to limit the charging current.
You can tell this by measuring as above (from the battery holder to the input plug) but check where both battery connectors go on the input plug.
If they both connect directly, you would need to control the charging rate externally.
Roland supply an AC adaptor so you may be able to get a replacement if yours is not working or you have lost it.
This is a high end product and you may damage it if you are not sure about this. So, you would need to get the proper adaptor.
I found the user manual for this.
http://www.rolandus.com/products/productdetails.php?ProductId=960
It says that the unit cannot recharge NiMH batteries, so you have to charge them yourself.
It also says several times that you should use their adaptor. While this may be to their advantage, you probably should follow this advice.
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 78 ·
17K
9K
