Find the 50th derivative of the function
The discussion focuses on finding the first five derivatives of the function y = sin(3x) and establishing a rule for determining the 50th derivative. Participants identify a pattern in the derivatives, noting that odd derivatives yield cosine terms and even derivatives yield sine terms, with coefficients increasing as powers of 3. The pattern suggests that the nth derivative can be expressed in terms of sine and cosine, alternating signs based on whether n is even or odd. Ultimately, the conversation emphasizes recognizing this pattern to simplify the calculation of higher-order derivatives. Understanding this approach allows for efficient determination of the 50th derivative.
Mathysics
Find the first, second, third, fourth, fifth derivatives of the function y = sin 3x.
Find a rule that can help to find the 50th derivative of the function.
It's urgent!
y= sin x y= cos x
y' = cos x y' = -sin x
y= sin ax y= cos ax
y' = a sin cos ax y' = -a sin ax
My attempt to the question: y = -a^n sin ax for even
y = a^n cos ax for odd
Plz show steps so that i can follow, cheers
sorry it should be the 50th derivative
It's urgent!
y= sin x y= cos x
y= sin ax y= cos ax
this to me is like a "puzle"; like the problem "find i^15" you find a pattern w/o having to go the whole way. Same here.
So you see the FIRST diff is pos and has the coeff of 3^1 and has "cos" in it
The SECOND diff is neg, coeff is 3^2 and has "sin" in it
The THIRD is neg, coeff is 3^3 and has "cos" in it
The FOURTH is pos, coeff is 3^4 and has "sin" in it..... ummmmm, can you see what the FORTY EIGHTH is now? then so easy to go to the 49th and 50th from there.
Trying hard NOT to give you the ANSWER... AND... apologies if my differentiation is wrong... I'm giving you a pattern to go by... I think diff of sin3x is 3cos3x and then diff of cos3s is -3sin3x? if wrong, FIX that part... I'm trying to show you a PATTERN.
Good luck,
LarryR : )
i know it now...
is (-1)^n/2 x a^n cos ax (for even)
thx for the help :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
