Find the acceleration of a pulley system
The discussion focuses on calculating the acceleration of a pulley system involving two masses, m1 = 0.1 kg and m2 = 0.3 kg. The tension in the rope is consistent across all segments due to the negligible mass of the pulley and the non-stretchable nature of the rope. The forces acting on the system are derived from the gravitational force on each mass, specifically F1 = (m2 * g)/2 and F2 = m1 * g. The net force is determined by the difference between these two forces, leading to the calculation of acceleration.
  • Understanding of Newton's laws of motion
  • Basic knowledge of gravitational force calculations
  • Familiarity with tension in ropes and pulleys
  • Ability to set up and solve equations of motion
  • Study the principles of Newton's second law of motion in detail
  • Learn about the dynamics of pulley systems and their applications
  • Explore the concept of tension in non-stretchable ropes
  • Investigate the effects of friction in pulley systems
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for practical examples of pulley systems and acceleration calculations.
AndrejN96
Find the acceleration of the system shown on the image, given m1=0.1kg and m2=0.3kg. Mass of pulleys is to be disregarded, and rope is non-stretchable.
m1*a=m1*g-T
I am unsure of how the forces of the second body would act and in what direction. Any help is appreciated.
Look at m2. It obviously pull the pulley with a force m2 * g. And that force divides in two parts...
Imagine that your mass is, for example, 70 kg, and hence your weight 70 * 9,8 = 686 N, and that you sit on the table of a swing that is fastened to an horizontal beam above with two chains. How much of your weight do you think is supported by each chain...? Well, the same thing happens with m2
My first thought was that it spreads the force applied in half, but how would the equations look like in that case?
Leave the equations apart for the moment, and just think about the forces involved. ¿What force is caused by m1? And what forces are caused by m2?
Well m1 would cause tension on the rope, and m2 would cause tension on both parts of the rope but with lower intensity (?)
Yes, but how much lower...? You have already written the right answer above...
Once you decide which are the forces involved, write them down and/or calculate them, and then you should deduce the net force.
I just did some more research in literature I have on physics. It says the tension would be the same in all 3 places of the pulley system, because the rope and pulley are light enough to be disregarded.
Look at the right rope, the one that is anchored to the floor. Along that length of rope, there is a force that is one-half of m2 * g. It is canceled by the same reaction from the roof.
Now, we look at the left rope rising from the pulley that holds m2. Along that length of rope, you also have one-half of the force caused by m2 Let's write it down: F1 = (m2 * g)/2.
But that length of rope is also affected by another pulling force, that coming from m1. We also write it down: F2 = m1 * g.
It's easy to see that F1 and F2 are opposed. Evidently, the net force is their difference...
Go on now... There is little left to solve the problem...
This is only true of the system is in equilibrium. In general the system will be accelerated and the only thing you can say about the tension in the rope is that it is the same in all parts. You will then have to relate the tension to the acceleration and geometry of the problem.
Yes, thanks, this was the confirmation that I needed. Cheers!
  • · Replies 17 ·
  • · Replies 22 ·
