Find the acceleration of the object
  • Thread starter Thread starter TyErd
    Acceleration
The discussion focuses on calculating the acceleration of an object influenced by gravitational and braking forces. The equation vf^2 = vi^2 + 2*a*s is suggested for finding acceleration, with components including gravitational acceleration (g*sinθ) and frictional force (af). Participants clarify that the net acceleration (a) is derived from the difference between gravitational force and frictional force, leading to confusion about the signs and directions of these forces. The relationship between the calculated accelerations and their respective directions is emphasized, noting that while both represent acceleration, they act in opposite directions. The conversation concludes with a reiteration of the importance of understanding the net forces acting on the object.
TyErd
please open the word document.
This questions really frustrating me
You can find the acceleration of the object by using
vf^2 = vi^2 + 2*a*s. vi and s is given. Find a.
This acceleration has two components. One the component of g which acts in the downward direction. And the other due to braking force, which acts in the opposite direction of the motion. In the diagram sinθ is given. (10/100).
Write down the expression for the acceleration and solve the problem..
um to find acceleration can't you use a=gsinθ, but if you use that its 10xsin(5.740) which equaks 1.001 because if sinθ=10/100 then θ=5.74. However if I use your equation i get a=4.5m/s/s
The acceleration a is correct.
Now a = af - g*sinθ, where af is the acceleration due to frictional force.
how do i calculate af?
In the problem they have asked
What is the constant braking force?
So you have find af, then the braking force = m*af.
You have found a and g*sinθ. Using the above equation find af.
so is af = 4.500 - 1.001?, then the braking force is 1000*3.499=3499?
so then what is the driving force?
is it just 1000N?
This step is wrong.
af = a + g*sinθ.
Αnd what do you mean by driving force?
Sledge moves down due to gravitational force. The frictional force stops it.
whats the difference between a and gsinθ?
mg*sinθ ...> Force acting on the sledge due to gravity in the downward direction
μ*mg*cosθ...>Frictional force in the upward direction = m*af
Net retarding force acting on the sledge is
mg*sinθ - m*af = - m*a.
ok we calculated before that gsinθ = 1.001. so that's the acceleration downwards direction. then we calculated a to be 4.500 using that equation. why are they different when there both acceleration?
When you are using the equation vf^2 = vi^2 + 2*a*s. to find a, you are getting the acceleration -4.5 ms^-2. whereas g*sinθ +1. There directions are different.
  • · Replies 38 ·
