Find the current through a complicated circuit
  • Thread starter Thread starter Jaccobtw
    Circuit Current
39 replies · 5K views
Jaccobtw
Six 100 ohm resistors are soldered together to form a regular tetrahedron. If the terminals of a 9V battery are wired to two of the vertices, how much current in A (amps) will flow from the battery?
V = IR
Yeah so I'm confused about this circuit because it has an overlapping path. My guess is that the current doesn't flow in one of the two paths in the middle but I don't have a good reason for it (I don't know why). I suppose there is symmetry but I haven't been able to find good videos on symmetry on YouTube. Can you help me solve the middle portion of this circuit? Much appreciated.
Discussion
Do you know about Kirchhoff's laws?
Jaccobtw said:
Homework Statement:: Six 100 ohm resistors are soldered together to form a regular tetrahedron. If the terminals of a 9V battery are wired to two of the vertices, how much current in A (amps) will flow from the battery?
Relevant Equations:: V = IR
Where is the battery connected? What in the world does this mean for any connections?
1) As berkeman pointed out, the problem statement is meaningless until you specify WHAT vertices get the 9V
2) I understand exactly what the 3D circuit looks like but you need to redraw it in 2D so it is more amenable to normal circuit analysis.
Not so hasty! Being a tetrahedron, it doesn't matter which two vertices you pick. (Any pair of vertices is related to any other pair by a rotation.)
To OP: once you've picked two vertices arbitrarily, can you use the symmetry to suggest i) which resistors have equal currents flowing through them and ii) which resistors have no current flowing through them? Follow-up: what's a simpler equivalent circuit?
Nuh-uh! it depends on where the dot goes in that middle bit! :wink:
Mike, you are misreading the 3D circuit. I think it's quite clear. Or are you joshing us? Again. Still. You need to stop that dammit ; you confuse me ! Besides you name's Mike, not Josh.
Well, I've never, ever seen a schematic with a fade to try to explain the connectivity. So you just stand down there young feller, util the OP can post a proper schematic diagram for us to help him on... :smile:
haruspex said:
But the circuit can be laid out as a 2D figure with no crossings, which would be a good start.
See item #2 in post #4
Do you mean the dot that doesn't exist?
That style of wires crossing each other without connecting at least used to be somewhat common, and well understood.
And it sure cut down on the time in the drafting department!
Either way, the statement that the resistors form the edges of a tetrahedron should be sufficient wthout the image.
As for the problem at hand, it should be quite clear that the circuit is a parallel coupling of a single resistor (the one on the edge between the connection points) and the rest. The ”rest” form a circuit that can be easily flattened and analysed.
Pick any vertex and look straight into it and what would you see?
Guys does it matter if it is a tetrahedron or just a square with all its sides and its diagonals resistors? I don't think it matters, it is the lumped model in circuit theory that makes it not matter.
I think a square with all its sides and its diagonals resistors would be a different configuration.
I think I figured it out. I connected the terminals to the left most and right most vertices, got rid of the middle vertical resistor due to symmetry, and the rest is just adding up the resistors in series and parallel.
Yes it would be a different configuration IF you going to do complete field analysis, but if you are interested only for voltages and currents I think it doesn't matter.
I can see that both have four vertices each with three connections and in that sense they should be the same electrically but I can't see how one morphs into the other. But then I'm not a topologist. Also, the tetrahedron projects into a 2D plane with no overlap while the square does not.
phinds said:
A regular tetrahedron is a 3D figure. The fade is just because one resistor goes behind a front one.
And because the person who wrote this problem is a physicist, not an EE. Granted the words are clear, but the schematic doesn't follow normal standards. Components don't fade, wires don't cross through/over components. For bonus points you follow the old Mil-Stds, where wires only cross like "X" when they don't connect. If they connect, they are only drawn as "T" with a dot.
In any case, whenever you see this sort of problem, the first thing you want to look for are simplifications due to symmetry arguments as @ergospherical said. There are 4 vertices, two are connected to the source, what do you know about the voltage at the other two vertices?
If you get rid of a resistor even if it has no net current flowing, I think that changes the circuit.
  • Skeptical
Just lift one of the vertices out of the plane.
Nope. If the current is zero, the voltage drop is zero, whether R=1Ω or 10MΩ. So you can change its value to ∞ provided you know that the current will always be zero. Same with branches that you know are 0V, those can be replaced with short circuits.
Seriously guys what does it matter from the point of view of circuit theory for the angles between the resistors and the length of resistors, given they all are 100ohm. Only if you going to view this circuit from the point of view of EM fields then it matters of course
Also note that when they say the source can be connected across any branch, that means you can pick whichever one makes it easier to draw or visualize.
Anyway, this is a better schematic without the irrelevant geometry stuff.
Well, I think the ”best” planar diagram is the one that follows from doing this:
It is the approach that conserves most of the symmetry of the setup. Of course, all of this is quite moot and not really clarifying the description of the circuit since it was adequately described in words in the OP:
I think this is quite adequate.
Nice, but can you give the answer you got for completeness of this thread?
