Find the exact value of this inverse function
14 replies · 5K views · last reply
1irishman
Find the exact value of cos(2arcsin(-1/8))
make use of the double angle formula
let arcsin(-1/8)=theta
then sin theta= -1/8
a=sqrt63=3sqrt7
and that is as far as i could go...please help? Thank you.
So now evaluate cos(2theta).
1irishman said:
a=sqrt63=3sqrt7
Where does a come in?
OK. Still, you need to evaluate cos(2theta). One identity is cos(2theta) = cos^2(theta) - sin^2(theta). This identity appears in two other forms, one of which will be useful for this problem.
1irishman said:
i'm still lost...
Draw a picture of the angle θ and label the sides of a little triangle appropriately to have a sine of -1/8. You can read all six trig functions off that triangle and should be able to calculate cos(2θ) from there.
Since you were told "make use of the double angle formula", [itex]cos(2\theta)= cos^2(\theta)- sin^2(\theta)= 1- 2sin^2(\theta)[/itex].
You know that [itex]sin(\theta)= \frac{1}{8}[/itex].
1irishman said:
what does cos^2 equal?
cos2(θ) is just an abbreviation for (cos(θ))2.
Once you draw your right-triangle and label an angle [itex]\theta[/itex] then since sin[itex]\theta[/itex] = -1/8, you know what your opposite and hypotenuse sides are, then you can use pythagoras' theorem to find the 3rd side. This will give you cos[itex]\theta[/itex].
cos(2x)[itex]= cos^2(x)- sin^2(x)[/itex][itex]= (1- sin^2(x))- sin^2(x)= 1- 2sin^2(x)[/itex]
If x= arcsin(-1/8) what is sin(x)?
I just notice that I had said this same thing several days ago!
Mentallic said:
Right, so what is cos(2x) given that cos(2x)=cos^2(x)-sin^2(x) ?
Which, as I pointed out in the post that Irishman's post was in response to (and, I just noticed, several days ago!) , is equal to [itex]1- 2sin^2(x)[/itex].
Irishman, if sin(x)= -1/8, what is [itex]sin^2(x)[/itex]? What is [itex]1- 2sin^2(x)[/itex]?
Yes, I know, this identity has been mentioned at least 3 times in this thread now. It just seems like 1irishman is only considering and responding to the most recent reply in this thread each time he logs back on, so I felt the need to hold his hand as we guide him through the process...
1irishman said:
sin x is -1/8
