Find the Expression of an Electric Field Produced by a Dipole
The discussion focuses on deriving the electric field produced by an electric dipole located along the y-axis, with a dipole moment defined as p=2aq. The electric potential at a point P far from the dipole is expressed as V=k_{e}p \cos θ / r². To find the electric field, the gradient of the potential is utilized, leading to the expression \vec{E}=-\vec{\nabla} V(\vec{r}), which incorporates the dipole moment vector \vec{p} and the radial vector \hat{r}.
  • Understanding of electric dipole moment (p=2aq)
  • Familiarity with electric potential and electric field equations
  • Knowledge of vector calculus, specifically gradient operations
  • Basic principles of Taylor expansion in physics
  • Study the derivation of electric fields from potentials in electrostatics
  • Learn about Taylor expansion techniques in the context of physics
  • Explore the implications of dipole orientation on electric field calculations
  • Investigate the applications of electric dipoles in real-world scenarios, such as molecular interactions
Students and professionals in physics, particularly those specializing in electromagnetism, as well as researchers interested in electric field analysis and dipole interactions.
ladyrx2020
An electric dipole is located along the y-axis as shown in (picture attached). The magnitude of its electric dipole moment is defined as p=2aq.
(a) At a point P, which is far from the dipole (r>>a), show that the electric potential is
V=\frac{k_{e}pcosθ}{r^{2}}
(b) Find an expression of the electric field produced by the dipole in terms of the vectors \hat{r} and \vec{p} (the dipole moment).
p=2aq (Magnitude of the Electric Dipole Moment)
\vec{E}=k_{e}\frac{q}{r^{2}}\hat{r} (Electric Field at P created by a q charge)
Part (a):
V=\frac{k_{e}q}{r_{1}}-\frac{k_{e}q}{r_{2}}=\frac{k_{e}q}{r_{1}r_{2}}(r_{2}-r_{1})
Since r>>a and r_{2}-r_{1}≈2acosθ, then v≈\frac{k_{e}q}{r_{1}r_{2}}2acosθ≈\frac{k_{e}pcosθ}{r^{2}}
Part (b):
I need help with this part.
So far, I got that both +q and -q is E=k_{e}\frac{|q|}{r^{2}}
Not sure how to complete the rest since point P does not lie on the x-axis.
NOTE:
An electric dipole consists of two charges of equal magnitude and opposite sign separated by a distance of 2a. The electric dipole moment \vec{p} is directed from -q toward +q.
in part a) what happened to r1 in the denominator? p.s. I think you have written down the electric potential V incorrectly, it should not be:
V=\frac{k_{e}pcosθ}{r_{2}}
And for part b), you have written down the correct equation for the magnitude of the electric field due to a point particle, but what you need is the direction as well!
The idea is to perform a Taylor expansion.
The full expression for the potential reads
V(\vec{r})=q k_e \left (\frac{1}{\sqrt{(\vec{r}-a \vec{e}_y)^2}}-\frac{1}{\sqrt{(\vec{r}+a \vec{e}_y)^2}} \right ).
The point is that a/|\vec{r}|\ ll 1 if you look at the field from a distance far from the charges. Then in leading non-vanishing order in the expansion in powers of a/|\vec{r}| you find
V(\vec{r})=q k_e \left [-2a \vec{e}_y \cdot \vec{\nabla} \frac{1}{r} \right ]=k_e \frac{\vec{p} \cdot \vec{r}}{r^3}.
Note that the expression given in your posting cannot be correct for dimensional reasons!
You find the electric field by taking the gradient of the potential
\vec{E}=-\vec{\nabla} V(\vec{r}).
  • · Replies 28 ·
