Find the Fourier series solution to the differential equation
The discussion focuses on finding the Fourier series solution to the differential equation x'' + x = t, with boundary conditions x(0) = x(1) = 0. The user seeks clarification on the limits of integration for Bn and the application of Fourier series to non-periodic functions. It is established that since the right-hand side is not periodic, a Fourier integral approach is necessary, and the external force must be regularized. The conversation also highlights the need for a particular solution to the inhomogeneous equation before applying the general solution of the homogeneous equation.
  • Understanding of Fourier series and integrals
  • Knowledge of differential equations, specifically second-order linear equations
  • Familiarity with boundary value problems
  • Experience with regularization techniques in mathematical analysis
  • Study the application of Fourier integrals for non-periodic functions
  • Learn about regularization methods for handling non-Fourier-transformable functions
  • Explore the derivation of particular solutions for inhomogeneous differential equations
  • Investigate the relationship between boundary conditions and initial conditions in differential equations
Mathematicians, physicists, and engineers working on differential equations, particularly those dealing with boundary value problems and Fourier analysis.
Paradoxx
Find the Fourier series solution to the differential equation x"+x=t
It's given that x(0)=x(1)=0
So, I'm trying to find a Fourier serie to x(t) and f(t)=t, and I'm know it must a serie of sin...
So here's my question...the limits of integration to the Bn, how do I define them? Will it be like 0 to L to both series? And about the x", after a I find the f(x) Fourier series I must just derive it and replace in the x"??
t = Ʃ Tn sin (n∏x/L)
where f(t) = t = 2/L ∫ f(t) sin(n∏x/L)
If the period 2L = 2, my limits on the integral will be 0 to 1?
Since the right-hand side of the equation is not periodic, you have to use a Fourier integral rather than a Fourier series. Further one has to regularize the right-hand side, because it's not a Fourier-transformable function. I guess that the idea is that the external force is switched on at [itex]t=0[/itex]. So I'd write
[tex]t \rightarrow \Theta(t) t \exp(-\epsilon t).[/tex]
Then you can evaluate the Fourier transform of both the left-hand side and the right-hand side of the equation. At the end of the calculation, after transforming back to the time domain, you can take [itex]\epsilon \rightarrow 0^+[/itex].
I also don't understand, why you have given boundary conditions at t=0 and t=1 rather than an initial condition [itex]x(t=0)=x_0[/itex], [itex]\dot{x}(t=0)=v_0[/itex]. This you could solve by first finding a particular solution of the inhomogeneous equation (using the Fourier-integral ansatz) and then add the general solution of the homogeneous equation.
