Find the frequency in an LRC circuit
To find the frequency in an LRC circuit, the equation w = w0^2 - alpha^2 is used, but a negative result indicates that the circuit will not oscillate. This occurs when the damping factor (alpha) is greater than the natural frequency (w0). In such cases, the circuit is overdamped, and no oscillation frequency can be calculated. To address this, one must recognize that the circuit's behavior changes based on the values of R, L, and C. Understanding the relationship between these parameters is crucial for determining the circuit's oscillation characteristics.
tony873004
w=w0^2 - alpha^2
and then take the square root of this.
But I keep getting a negative number and I can't put this under the root symbol. I remeber he discussed this in class but I can't find it in my notes. How do I deal with the negative so I can find the frequency?
Not all RLC circuits will oscillate. If R, L, & C are such that
alpha > w0
you get the situation you are describing.
  • · Replies 21 ·
