Find the inverse of the polynomial.
The discussion focuses on finding the derivative of the inverse function, specifically (f^{-1})'(5) for the function f(x)=√(x³+x²+x+22). The correct approach involves determining f(1)=5, leading to f^{-1}(5)=1. Subsequently, the derivative is calculated using the formula (f^{-1})'(a)=1/f'(f^{-1}(a)), resulting in (f^{-1})'(5)=5/3. The participants emphasize the importance of guessing specific values when the function is complex to invert.
  • Understanding of inverse functions and their derivatives
  • Familiarity with the chain rule and differentiation techniques
  • Knowledge of polynomial functions and their properties
  • Ability to solve equations involving square roots
  • Study the application of the inverse function theorem in calculus
  • Practice finding derivatives of inverse functions with various examples
  • Learn about polynomial function behavior and root-finding techniques
  • Explore numerical methods for approximating function values
Students studying calculus, particularly those focusing on inverse functions and derivatives, as well as educators seeking examples for teaching these concepts.
jrjack
Find (f^{-1})'(a) of: f(x)=\sqrt{x^{3}+x^{2}+x+22} ; a=5.
(f^{-1})'(a)=\frac{1}{f'((f^{-1})(a))}
Well, I know to find an inverse: I need to set the equation equal to y, solve for x, then swap x and y. But I don't know how to solve this for x.
I have been searching the internet for a lesson on this type of problem but I am not finding anything.
I can find the derivative, but I don't think that helps me here.
f'(x)=\frac{1}{2}({x^{3}+x^{2}+x+22})^{-\frac{1}{2}}(3x^{2}+2x+1)
(f^{-1})(a)=\frac{1}{f'((f^{-1})(a))}
Don't try to find a general formula for the inverse. It's way too hard. You only need the value of the inverse at a=5. What's f^(-1)(5)? It's perfectly ok to guess.
Well, f(5)=\sqrt{177}\approx13.304
So, is the inverse 1/13.304, but then what is the derivative of the inverse?
Or the inverse of the derivative? at a=5f'(x)=\frac{1}{2}({x^{3}+x^{2}+x+22})^{-\frac{1}{2}}(3x^{2}+2x+1)
f'(5)=\frac{66}{2\sqrt{177}}
(f^{-1})'(5)=\frac{2\sqrt{177}}{66}\approx\frac{13}{33}
I'm not really sure of the correct guessing process.
My choices were 2/3, 5/3, 4/3, or 7/3. I guessed 2/3, but was wrong and the correct answer was 5/3. My guessing needs work.
To find f^(-1)(5) you want to find a value of x such that f(x)=5. As you said, f(5)=sqrt(177). So that's not it. f(0)=sqrt(22). That's not 5 either. Put some more values into f(x) and see if you can get it to come out 5.
f(1)=5
jrjack said:
f(1)=5
Ok, so f^(-1)(5)=1. That's the f^(-1)(a) in your formula, right?
In this formula?(f^{-1})(a)=\frac{1}{f&#039;((f^{-1})(a))}<br />
(f^{-1})(a)=\frac{1}{f&#039;(1)}
then
f&#039;(1)=\frac{1}{2}(25)^{-\frac{1}{2}}(6)
equals 3/5, and the inverse is 5/3.
So, is this the way I should go about these kind of problems?
then
Yes. That's the way to go. If a function is hard or impossible to invert, they'll probably make it easy to guess a specific value of the inverse, like in this problem.
BTW your formula should read (you're missing a prime)
(f^{-1})&#039;(a)=\frac{1}{f&#039;((f^{-1})(a))}
I am still a little confused, but thank you very much for your help.
I need to find and practice another one of these.
  • · Replies 105 ·
