Find the Maclaurin Series for tanx
10 replies · 27K views
turkcyclone
Find the terms through x^5 in the Maclaurin series for f(x)
f(x)=tanx
tanx=sinx/cosx
Maclaurin Series for:
sinx=x-x^3/3!+x^5/5!-x^7/7!...
cosx=1-x^2/2!+x^4/4!-X6/6!...
I have done tanx=sinx/cosx
So I need to solve for (x-x^3/3!+x^5/5!-x^7/7!+x^9/9!)/(1-x^2/2!+x^4/4!-X6/6!+x^8/8!),
but I don't know how to solve this. Can someone help me with my division? Thanks!
Cant you just find the Maclaurin series the direct way? By using the formula
[tex]\sum_{n=0}^{+\infty}{\frac{f^{(n)}(0)}{n!}x^n}[/tex]
So to find the term at [tex]x^5[/tex], you'll need to derive 5 times.
No, for this problem I am suppose to use the way I am trying, those were the directions.
So you'll need to find a power series [tex]\sum_{n=0}^{+\infty}{a_nx^n}[/tex] such that
[tex]\sum_{n=0}^{+\infty}{\frac{(-1)^n}{(2n+1)!}x^{2n+1}}=\sum_{n=0}^{+\infty}{a_nx^n}\sum_{n=0}^{+\infty}{\frac{(-1)^n}{(2n)!}x^{2n}}[/tex]
Perform the product (up to [tex]x^5[/tex]) and compare the coefficients...
Well, if you're not allowed to just expand the series with derivatives, you can do this:
[tex]\tan x = \frac{\sin x}{\cos x}[/tex]
[tex]\sum_{n=0}^\infty a_n x^n = \frac{x-\frac{x^3}{3!}+\frac{x^5}{5!}-...}{1-\frac{x^2}{2!}+\frac{x^4}{4!}-...}[/tex]
[tex](1-\frac{x^2}{2!}+\frac{x^4}{4!}-... )\sum_{n=0}^\infty a_n x^n = x-\frac{x^3}{3!}+\frac{x^5}{5!}-...[/tex]
Now multiply out the first few terms of the left side, up to terms of order [itex]x^5[/itex], and generate a set of linear equations in [itex]a_n[/itex] (since the coefficients of the powers on either side must be the same). Solve those and you have your answer.
Can you follow this and continue the long division to get the remaining terms?
[tex] \begin{array}{rc@{}c}<br /> & \multicolumn{2}{l}{\, \, \, x} \vspace*{0.12cm} \\<br /> \cline{2-3}<br /> \multicolumn{1}{r}{1-\frac{x^2}{2}+\frac{x^4}{4!}-\frac{x^6}{6!}+\dotsb \hspace*{-4.8pt}} & \multicolumn{1}{l}{ \hspace*{-5.6pt} \Big) \hspace*{4.6pt} x-\frac{x^3}{2}+\frac{x^5}{24}+\dotsb} \\<br /> & \multicolumn{2}{l}{\, \,\,\hspace{-18pt} -(x-\frac{x^3}{2}+\frac{x^5}{4!}+\dotsb}<br /> \\<br /> \vspace{1mm}<br /> \cline{2-3}<br /> \multicolumn{2}{1}{\,\,\,\hspace{150pt} 1/3 x^3+\dotsb} \\<br /> \vspace{1mm}<br /> \end{array}[/tex]
I actually started using that method and got stuck after the (x^3)/3.
Ok, the arithmetic is a mess. I got the third one that way but wouldn't want to get any more that way. Here's the latex for fun:
[tex] \begin{array}{rc@{}c}<br /> & \multicolumn{2}{l}{\, \, \, x+1/3 x^3} \vspace*{0.12cm} \\<br /> \cline{2-3}<br /> \multicolumn{1}{r}{1-\frac{x^2}{2}+\frac{x^4}{4!}-\frac{x^6}{6!}+\dotsb \hspace*{-4.8pt}} & \multicolumn{1}{l}{ \hspace*{-5.6pt} \Big) \hspace*{4.6pt} x-\frac{x^3}{2}+\frac{x^5}{24}+\dotsb} \\<br /> & \multicolumn{2}{l}{\, \,\,\hspace{-12pt} -(x-\frac{x^3}{2}+\frac{x^5}{4!}+\dotsb}<br /> \\<br /> \vspace{1mm}<br /> \cline{2-3}<br /> \multicolumn{2}{1}{\,\,\,\hspace{180pt} 1/3 x^3-1/30 x^5+\frac{6}{7!} x^7+\dotsb}\vspace{1mm} \\<br /> \multicolumn{2}{1}{\,\,\,\hspace{170pt} -(1/3 x^3-x^5/6+x^7/72+\dotsb} \\<br /> \cline{2-3}\\<br /> \multicolumn{2}{1}{\,\,\,\hspace{170pt} 2/15 x^5+\dotsb} \\<br /> \end{array}[/tex]
I tried it and you are right, it is a mess. I think I am going to talk to my instructor on and see if I can use the other method. Thanks for your help!
Wait a minute dude. It ain't messy enough to do that. He may say, "auh, poor dawg, what, you can't handle a lil' bit of arithmetic?" I mean, it's only two more. :)
Haha, okay I will try it. We just started the Maclaurin Series and this was the first problem, so I was frustrated when I couldn't get it and the solutions manual did a TERRIBLE job explaining how to get it. But I did a couple of more and starting to get the hang of it, so I will go back and try it again. Thanks again though!
