Find the Magnitude of the Magnetic Field in a moving loop
The discussion centers on calculating the magnitude of the magnetic field induced in a conducting square loop moving at a constant speed of 2.0 m/s, which generates a 0.63-V electromotive force (emf). Using the equation EMF = Blv, where l is the side length of the loop (0.30 m), the calculated magnetic field B is determined to be 1.05 T. The participants emphasize the importance of understanding the magnetic field's boundaries, noting that the loop must enter or exit a magnetic field to induce an emf.
  • Understanding of electromotive force (emf) and its calculation
  • Familiarity with the equation EMF = Blv
  • Knowledge of magnetic fields and their properties
  • Concept of magnetic flux and its relation to induced emf
  • Study the concept of magnetic flux and its calculation in different scenarios
  • Learn about Faraday's Law of electromagnetic induction
  • Explore the effects of magnetic field boundaries on induced emf
  • Investigate applications of induced emf in real-world electromagnetic systems
Physics students, educators, and professionals interested in electromagnetism, particularly those studying the principles of electromagnetic induction and magnetic fields.
Shinwasha
A conducting square loop placed in the xy plane (oriented with its horizontal and vertical sides parallel to the x and y axes) moves to the right across the y-axis at a constant speed of 2.0 m/s, a 0.63-V emf is induced in the loop. If the side length of the loop is 0.30 m, what is the magnitude of the magnetic field?
EMF = Blv
So my EMF is 0.63, V = 2.0m/s, l = .30m and B is unknown
Thus
0.63 T*m^2*s^-1/(2.0m*s^-1 * .30m) = B
0.63 T/.6 = B
1.05 T = B
Not sure where I'm going wrong here.
Isn't your equation for a straight section of wire only, not for a square loop ?
And what is known of the magnetic field? A direction, where are the bounds, is it constant ?
Magnetic Field is constant, the direction is into the positive z direction (guess I missed that part). I've tried to use ΔΦ/Δt, but not sure I did it right. Tried to take that fact it's traveling at 2m/s and the loop is 0.30 that
Δt= 0.30m/2m/s giving me 0.15 seconds to go through completely into the magnetic field.
a = 0.09m2
emf = 0.63 T*m2
Thus
0.63=(B)*(0.09)/0.15s
0.63*0.15/(0.09) = B
1.05 T = B
Gives the same answer.
BvU has a good point here, when asking about the magnetic field's boundaries.
If the magnetic field and loop have a constant, perpendicular orientation [that is the field is perpendicular to the sides, parallel with the loop's normal], the loop's size is fixed, and the field is not changing with time, then the loop needs to be passing into or out of one of the magnetic field's boundaries in order to get an emf.
In short, something or other needs to be causing a change to the magnetic flux through the loop, otherwise an emf would not be occurring.
Is there anything more you can tell us about the magnetic field (boundary edges, etc.), or something about the loop changing size or orientation?
[Edit: Btw, the 1.05 T figure is correct if the loop is entering or leaving a boundary that is parallel with the loop's side, and spans the entire side. But if that doesn't give the correct answer, is that at least the correct description of the boundary?]
The space to the right of the y-axis contains a uniform magnetic field of unknown magnitude that points in the positive z direction. As a conducting square loop placed in the xy plane (oriented with its horizontal and vertical sides parallel to the x and y axes) moves to the right across the y-axis at a constant speed of
Copied and pasted exactly. It's entering the magnetic field. That's all I get.
It's entering the magnetic field, nothing about magnetic field's boundaries.
The boundary is the y-axis.
For regions where x < 0, there is no magnetic field at all. For regions where x > 0, there is a magnetic field of unknown magnitude that points in the z direction. That's what was meant by saying, "the space to the right of the y-axis contains a uniform magnetic field of unknown [...]" That specifies the boundary, assuming that the space to the left of the y-axis contains 0 magnetic field. That's the assumption that I would make anyway.
That said, your answer of 1.05 T looks right to me. :smile:
Shinwasha said:
That's all I get
Makes a big difference with post #1, though. I understand you didn't realize that when you posted, but it sure is a reminder that a complete and concise problem statement is extremely important, not only for yourself (to order your thoughts and get lined up for the equation gathering phase), but also to get adequate assistance !
And putting together the relevant equations is indispensable too - if necessary in more than one iteration.:rolleyes:
