Find the mean and variance of Y^2
  • Thread starter Thread starter BrownianMan
    Mean Variance
The discussion focuses on calculating the mean and variance of the random variable Y^2, where Y represents the number of heads obtained from tossing a coin three times. The correct mean is determined to be E[Y^2] = 3, calculated using the probabilities of each outcome. The variance is computed as Var[Y^2] = 15/2, following the formula for variance. Additionally, the discussion touches on the relationship between the exponential distribution and the geometric distribution, specifically regarding the greatest integer function applied to an exponentially distributed variable.
  • Understanding of discrete random variables and their properties
  • Familiarity with probability distributions, specifically binomial and geometric distributions
  • Knowledge of expectation and variance calculations
  • Basic concepts of exponential distribution and its applications
  • Research the properties of binomial distributions, particularly in relation to coin tosses
  • Learn about the relationship between exponential and geometric distributions
  • Study the calculation of expected values and variances for transformed random variables
  • Explore the implications of the greatest integer function on continuous distributions
Students and professionals in statistics, data science, and probability theory, particularly those interested in random variable transformations and distribution properties.
BrownianMan
Let Y by the number of heads obtained if a coin is tossed three times. Find the mean and variance of Y^2.
For the mean I get, (0+1+4+9)/4=7/2, and for variance I get (0+1+16+81)/4 - (7/2)^2 = 49/4. Is this correct?
For the following question, I'm not sure how to begin:
Show that if T has exponential distribution with rate lambda, then int(T), the greatest integer less than or equal to T, has geometric (p) distribution on {0, 1, 2,...}, and find p in terms of lambda.
not quite, the definition of mean of a discrete RV is
E(Y) = \Sigma p_i(Y=y_i) y_i
so you need to include the probability of each outcome. The values you worte down would only be true if the probability of a number of heads is the same in each case, p(H=0) = p(H=1) = p(H=2) = p(H=3) which is clearly not true
It's suppose to be the expectation of Y^2 though, not Y...
Ok, so would E[Y^2] = 3, and Var[Y^2] = 7.5?
ok, show us how you got those values
E[Y^2] = (1/8)(0)+(3/8)(1)+(3/8)(4)+(1/8)(9) = 24/8 = 3
Var[Y^2] = [(1/8)(0^2)+(3/8)(1^2)+(3/8)(4^2)+(1/8)(9^2)] - 3^2 = 15/2
method looks good to me
E[Y^2]
Var[Y^2] = E[(Y^2)^2] - (E[Y^2])^2
Thanks!
Any ideas for the second question?
