Find the Molarity of a Solution Using Concentrated Ammonia (28% by Mass)
The discussion focuses on calculating the molarity of a solution created by mixing 35.5 mL of concentrated ammonia (28.0% by mass, density 0.880 g/mL) with water to make a total volume of 250 mL. The correct approach involves first calculating the mass of the ammonia solution, which is 31.24 g, and then determining the mass of ammonia present by applying the mass percentage formula. The final molarity is derived from the number of moles of ammonia divided by the total volume in liters, resulting in a concentration that reflects the 28% solution.
  • Understanding of molarity calculations
  • Knowledge of mass percentage and density concepts
  • Familiarity with the properties of ammonia
  • Basic skills in algebra for solving equations
  • Learn how to calculate molarity from mass and volume using different solutes
  • Study the properties and safety measures when handling ammonia solutions
  • Explore the concept of density and its applications in solution chemistry
  • Review the principles of solution preparation and dilution techniques
Chemistry students, particularly those in General and Analytical Chemistry courses, as well as educators and professionals involved in laboratory work with chemical solutions.
antonisz
Calculate the molarity of a solution made by adding 35.5 mL of concentrated ammonia (28.0 % by mass, density 0.880 g/mL) to some water in a volumetric flask, then adding water to the mark to make exactly 250 mL of solution. (It is important to add concentrated acid or base to water, rather than the other way, to minimize splashing and maximize safety.)
u
Molarity = mol / liter
Mass % = (grams of solute / grams of solution) * 100
Density = mass / volume
a) I used the ml of NH3 to find the number of grams of NH3 - 35.5 ml * 0.88 g/ml = 31.24 g
b) I then used that amount to find the number of mole - (31.24 g / 17.03) = 1.8344 mol of NH3
This is where I am stuck. I used the % mass formula to find that the total grams of solution is 111.57 (0.28 = 31.24 / x and cross multiply), but I have no idea where to go from here.
I know that if I compute the molarity using (1.8344 mol / .250 L) I'll get the moles of NH3 at concentration 100%, would I need to multiply the number of moles by 0.28 to get the 28% concentration?
*Edit* Yes, it turns out that that would make sense, too much chemistry for the last 2 hours! I haven't taken Gen Chem in a couple years and getting thrown into Analytical, I should have reviewed some of these concepts. [/B]
u
In step (a), you have found the mass of ammonia solution . The mass of ammonia molecules in this solution is 28% of this. Remember that ammonia is a gas, the stuff you are working with is ammonia gas dissolved in water. Taking 28% of 31.24 g will tell you how many grams of ammonia are actually present in the solution. Continue on as you have done to calculate the final concentration.
u
I think you are making a mistake while calculating the mass of ammonia. The solution contains 28% by mass of ammonia. 35.5 x .88 will give you the mass of the solution, not NH3. Multiply that further by 0.28 to get the grams of ammonia. Then retry solving the problem.
Yes, thank you. I caught my mistake. Just some careless thinking on my part.
Thank you for the response.
Glad to help :)
12K
