Find the normalization constant ##A##
14 replies · 5K views
Mutatis
Find the noralization constant ##A## of the function bellow: $$ \psi(x) = A e^\left(i k x -x^2 \right) \left[ 1 + e^\left(-i \alpha \right) \right], $$ ##\alpha## is also a constant.
##\int_{-\infty}^{\infty} e^\left(-\lambda x^2 \right) \, dx = \sqrt {\frac {\pi} {\lambda} }##
Well, first I've tried to find the density of probability: $$ \left| \psi(x) \right|^2 = 2 \left| A \right|^2 e^\left( -2 x^2 \right) + e^\left( -2 i \alpha x^2 \right) +e^\left(2 i \alpha x^2 \right) .$$ Then I have no idea how to solve the integral to normalize ##\psi(x)##... The fisrt two terms I've solved using the gaussian integral above, but I can't do it to the third term: $$ 2 \left| A \right|^2 \left( \int_{-\infty}^{\infty} e^\left( -2 x^2 \right) dx + \int_{-\infty}^{\infty} e^\left( -2 i \alpha x^2 \right) dx + \int_{-\infty}^{\infty} e^\left(2 i \alpha x^2 \right) dx \right)= 1 \\ 2 \left| A \right|^2 \left( \frac {\sqrt {2 \pi}} {2} + \frac {\sqrt {2 i \alpha \pi}} {2 i \alpha} + \int_{-\infty}^{\infty} e^\left(2 i \alpha x^2 \right) dx \right)= 1$$.
I don't know if I'm doing it right, but I have no idea to get this solved... Help!
This is not correct. Check your work. If you don't see your mistake, then show us how you got this result. You should not get ##\alpha## multiplying ##x^2## in any of the exponents. ##|A|^2## should be an overall factor of the entire result.
As has been pointed out by TSny, the ##A^*A## should be an overall factor of the probability density. You made another mistake multiplying the exponentials when finding the probability density: don't you know that ##e^a e^b = e^{a+b}## and not ##e^{ab}##?...
You made mistake in multiplying the exponential. The normalization factor should come as an overall factor.
Embedded video removed by mentor. Posting complete solutions is not permitted at this site.
Ok guys, thank you. I'm going to review my calculations and then I get back here.
So, I'm here again... I've done my calculations right this time, but I still can't get ##A## though... I got the probability density: $$ \left| \psi(x) \right|^2 = \left| A \right|^2 \left[ 2 e^\left(-2 x^2\right) +e^\left(-2x^2 +i\alpha \right) + e^\left(-2x^2 -i\alpha \right) \right] . $$
And then I coulnd't get ##\psi## normalizated... I've calculated all of the integrals above and that's what I got $$ \left| A \right|^2 \sqrt {\frac {\pi} {2}} \left(2 - e^{i\alpha} + e^{-i\alpha} \right) = 1.$$ So, I don't know what to do next. What do think?
Check whether or not the minus sign is correct for the middle term. Note that with this minus sign, your expression will not be real and therefore cannot equal 1. Otherwise, I think your expression is right.
I think you can assume that A is a real, positive number. Otherwise, there will not be a unique answer. So, once you fix the sign error, you can just solve the expression for A. (You can combine the two complex exponentials into a trig function.)
Note that the expression in ##\alpha## is just a constant factor, so it didn't need to get tangled up in your integral. Or your expression for ##|\psi(x)|^2##.
This question is from the master degree qualification test that I'm intended to do here in my city (northeast of Brazil). I've obtained ##A## doing what you've told me to. First I got the exponentials in terms of ##cosh##, then I've turned it into a constant ##w## so I got: $$ \frac {\left| A \right|^2} {2} \sqrt \frac {\pi} {2} \left( 1 + \cosh(i \alpha) \right) = 1 \\ A = \sqrt \frac {2} {w} \left( \frac {2} {\pi} \right) ^{1/4}. $$
I don't know if this is right, because It is a very ugly equation.
You should have ##cos## not ##cosh## in that equation.
Since the exponentials have imaginary arguments, it will be nicer to express things in terms of the cosine function with real argument rather than in terms of the cosh function with imaginary argument. @PeroK has pointed this out.
https://webhome.phy.duke.edu/~rgb/Class/phy51/phy51/node15.html
then I've turned it into a constant ##w## so I got: $$ \frac {\left| A \right|^2} {2} \sqrt \frac {\pi} {2} \left( 1 + \cosh(i \alpha) \right)$$
I don't see where the denominator of 2 (under |A|2) is coming from.
Now I've changed it to ##cos(\alpha)##. But it doesn't change the final result in terms of ##w## like I wrote above.
To write the exponentials in terms of cossine I'd divided ## \left( 2 + e^{i \alpha} + e^{-i\alpha} \right) ## for ##2##. Is this an aceptable answer? Because what I've got to do next is to find the current of probability ##j(x)##.
Note that ## \left( 2 + e^{i \alpha} + e^{-i\alpha} \right) = \left(2 + 2\cos\alpha \right) = 2\left(1 + \cos\alpha \right) ##
If you want, you can use another identity to write this as ##2\left(2\cos^2\frac{\alpha}{2} \right) = 4 \cos^2 \frac{\alpha}{2}##
So, this is essentially your ##w##, and ##\sqrt{w}## has a nice simple form.
Thank you guys! I got this solved. My problem this time is to find ##<x^2>##. I did some calculation and it leads me to ##<x^2> = \frac {1} {8} ## and it doesn't seems the right answer.
I get a larger value for ##\langle x^2 \rangle##. What expression do you get for ##|\psi (x)|^2## if you simplify it as much as possible?
