Find the points on a graph at which the tangent line is parallel
18 replies · 4K views · last reply
thatguythere
Find the points on the graph y=x^3/2 - x^1/2 at which the tangent line is parallel to y-x=3.
First I found that the derivative of y=x^3/2 - x^1/2 is 1x.
I then rewrote the other line as y = 3+x and found the derivative to be 1.
Then I set 1x = 1, therefore x = 1
Now I plugged it back into the original function and got y = 1^3/2-1^1/2 = 1
So the point is (1,1).
But I have no idea if I am anywhere near correct. Any help would be greatly appreciated.
No it isn't. How did you get 1x for the derivative?
Also, calculus questions should be posted in "Calculus & Beyond" not in the Precalc Math section. I am moving this thread.
My apologies for the mispost. Also I do not know what I was thinking with that derivative. It should be 3x^1/2/2-1/2x^1/2 correct?
Therefore, setting 3x^1/2/2-1/2x^1/2 = 1, I get x = 1/9, 1.
Almost, and you need to use parentheses around the exponents if you write using ordinary text.
The first term, (3/2)x^(1/2), in your derivative is correct, but the second one isn't.
Here's the first part of what you wrote: 3x^1/2/2
Using the precedence of operations, this is the same as if written ((3x^1)/2)/2
Or, in LaTeX:
$$ \frac{\frac{3x^1}{2}}{2} = \frac{3x^1}{4}$$
The second part of the derivative, (1/2)x^(-1/2) = (1)/2x^(1/2) is incorrect?
(1/2)x^(-1/2) is correct, but it's not equal to (1)/2x^(1/2).
thatguythere said:
Ah, perhaps it is (1)/2√x
This is also incorrect.
According to the order of operations, (1)/2x^(1/2) means
$$ \frac{1}{2}\cdot x^{1/2}$$
Similarly, (1)/2√x means
$$ \frac{1}{2}\cdot \sqrt{x}$$
If you write these using inline text, this will do it: 1/(2x^(1/2)) or 1/(2√x). Now it's clear what's in the denominator.
Regardless of my incorrect use of inline text. Did I solve for x properly when I came to x= 1/9 and 1?
(3x^(1/2))/2 - 1/(2x^(1/2)) = 1
(3x^(1/2))/2 · 2x^(1/2) - 1/(2x^(1/2)) · 2x^(1/2) = 1 · 2x^(1/2)
3x - x^0 = 2x^(1/2)
3x - 1 - 2x^(1/2) = 0
3u^2 - 2u - 1 = 0 where u = x^(1/2)
(3u+1)(u-1) = 0
Now 3u+1 = 0
3u = -1
(3u)/3 = -1/3
u = -1/3
x^(1/2) = -1/3
x = (-1/3)^2
x = 1/9
3x - x^0 = 2x^(1/2)
(3u+1)(u-1) = 0
Now 3u+1 = 0
3u = -1
(3u)/3 = -1/3
u = -1/3
So x1/2 = -1/3, which means there is no solution for x. There is no real number whose (principal) square root is negative.
thatguythere said:
x^(1/2) = -1/3
x = (-1/3)^2
x = 1/9
Ah. So the only solution is x = 1, which I plug back into the original equation y = x^(3/2) - x^(1/2), and gives me 0? Therefore, the point at which the tangent line is parallel to y-x=3 is (1,0)?
