Find the range of possible dimensions for a volume
The discussion revolves around finding the range of possible dimensions for a storage container that must have a volume of at least 8436 m³. The dimensions are related by specific equations: the length is one meter more than triple the width, and the height is five meters less than double the width.
  • Participants discuss the initial calculations leading to specific dimensions and the need to establish a range for the dimensions based on the volume constraint. There is confusion regarding the correct formulation of inequalities and equations for the dimensions.
Participants are actively exploring the relationships between width, length, and height, with some suggesting that the width must be at least 12. There is ongoing clarification about how to express the constraints for length and height based on the width, and the discussion reflects a mix of understanding and confusion about the problem setup.
Some participants note that the original polynomial equation derived does not represent an inequality, which is essential for determining the range of dimensions. The constraints on dimensions based on the relationships provided in the problem statement are also under examination.
Traced
The specifications for a storage container state that the length is 1 metre more than triple the width and the height is 5 metres less than double the width. Find the range of possible dimensions for a volume of at least 8436m^3
None
I understand how to get the dimensions that equal 8436m^3. What I don't understand is how to find the range of all possible dimensions.
I solved the inequality to get ##6w^{3}-13w^{2}-5w-8436##
Using systematic guessing I found the root is x=4, so the factor is x-4.
Dividing (x-4) into ##6w^{3}-13w^{2}-5w-8436## gives me ##6w^{2}+59w+703##
so, ##6w^3-13w^{2}-5w-8436 = (w-12)(6w^{2}+59w+703)##.
this means that
w=12
l=3(12)+1=37
h=2(12)-5=19
v=lwh
v=8436
This is as far as I get. I don't understand how to find the range of all possible dimensions.
It says the range of dimensions l,w,h of at least 8436 m^3
so l=1, w=1, h=1 gives 1 m^3 which is less than 8436 m^3
But I think you also have to consider the limits for l, w, h ie ##l = 3w## and ##h = 2w - 5##
since h must be greater than 0 then 2w=5 meaning w>=xxx at a minimum and similarly for the maximums too.
I'm still confused. Could you explain it a bit more please? Right now I have 3 dimensions, l=37, w=12 and h=19. The dimensions I have the minimum dimensions that will give a box of ##8436m^{3}##. I'm confused by
I guess I could do something like this?
w>=12
l>=37
h>=19
I don't know if that is how the question is meant to be solved though.
Traced said:
Homework Statement:: The specifications for a storage container state that the length is 1 metre more than triple the width and the height is 5 metres less than double the width. Find the range of possible dimensions for a volume of at least 8436m^3
Relevant Equations:: None
That's not an inequality -- it should include <, or >, or >=, or <=.
The actual inequality is ##w(3w + 1)(2w - 5) \ge 8436## (##m^3##).
What you solved was the equation ## w(3w + 1)(2w - 5) = 8436##
this means that
w=12
l=3(12)+1=37
h=2(12)-5=19
Assuming your algebra is correct, if w, l and h are as above, you'll get the minimum volume. If you increase w, that will cause l and h to increase, and result in a larger volume. So the range for w is ##w \ge 12##. What would be the ranges for l and h?
Traced said:
v=lwh
v=8436
w>=12
l>=37
h>=19
I think you added this after I started my earlier reply. I believe you're on the right track here, but you still need to work in the constraints that l = 3w + 1, and h = 2w - 5.
So you'll have an inequality for w, but equations for l and h, both of which are in terms of w.
You mean w-12, right?
Does the polynomial you found have any other real roots?
What does that tell you about the values it takes as you increase w?
Sorry I'm still confused. I'm just not really understanding this.
From the problem statement in post 1:
From post 3:
Traced said:
w>=12
l>=37
h>=19
The first inequality is correct, but l and h are constrained by the conditions in the problem statement. So w can be any value >= 12, but the values of l and h depend directly on the value of w.
From post 3:
Do you mean like this?
l>=3w+1 and h>=2w-5?
This way the length and the height have the constraints.
No. Here's what I mean:
##w \ge 12##
##l = 3w + 1##
##h = 2w - 5##
w can take on any value 12 or larger, but the two equations guarantee that l and h satisfy the given constraints. They wouldn't do so with the two inequalities you wrote.
  • · Replies 23 ·
  • · Replies 30 ·
