Find the relation between x,y and z
  • Thread starter Thread starter utkarshakash
    Relation
The discussion centers on finding the relationship between coplanar points A, B, C, and D, represented by their coordinates. The equation a(2-x, 2, 2) + b(2, 2-y, 2) + c(2, 2, 2-z) = (1, 1, 1) is analyzed, leading to the conclusion that ax = by = cz = k. However, the derived relationship 1/x + 1/y + 1/z = 1 does not hold in the specific case presented. An additional constraint regarding the collinearity of the vectors is highlighted, indicating that arbitrary coefficients a, b, and c can only generate vectors within the desired plane if the vectors are not collinear. The importance of this constraint is emphasized for achieving the correct relationship.
utkarshakash
The coplanar points A,B,C,D are (2-x, 2,2); (2,2-y,2); (2,2,2-z): (1,1,1)
a(2-x, 2,2) + b(2,2-y,2) + c(2,2,2-z) = (1,1,1)
Equating respective components
ax=by=cz=k
The answer is 1/x + 1/y + 1/z = 1 but in my case it does not satisfy this.
ax=by=cz=k
Look here: http://mathworld.wolfram.com/Coplanar.html
True, but there is another constraint on a, b, c. If the three vectors on the left are not collinear then with arbitrary a, b and c you could generate any vector in the space, not just those in the desired plane.
If you bring in that extra constraint, the result does follow.
