Find the speed of the source (Doppler Effect)
22 replies · 7K views
mastermind1
A kid is riding a bike and is ringing bell of 3000 Hz. You are standing still on the sidewalk.When the bicycle moves toward you, you hear a shift in the frequency of the bell. In addition, when the bicycle moves away from you, you hear a different shift in the frequency of the bell. If there is a 30 Hz change in the frequencies that you hear for the bell as the bicycle approaches you and then moves away from you, what is the speed (in m/s) of the bicycle? (Write your answer to the nearest 0.01 m/s.)
1. Homework Statement
Frequency(source)(fs) = 3000 Hz
speed(observer)(vo) = 0 m/s
Frequency(towards)(ft)= 3030 Hz (NOT SURE)
Frequency(away)(fa) = 2970 Hz (NOT SURE)
speed of sound(v) = 343 m/s
fo = ((v+vo)/(v-vs)) * fs Bike is moving TOWARDS me
fo = ((v-vo)/(v+vs)) * fs Bike is moving AWAY from me
Towards
3030Hz/3000Hz = (343 m/s) / (343 m/s - vs)
(1.01)(343 m/s - vs) = 343 m/s
345.20 m/s - 1.01 vs = 343 m/s
vs = 2.18 m/s
I do the same thing using the AWAY equation, and i get the same answer.
However, that answer is incorrect. I do not know what I am doing wrong.
mfb said:
The 30 Hz difference are between "towards you" and "away from you". They are not relative to the 3000 Hz.
Could you please elaborate on that. And, give me a hint.
If the bike approaches you, the frequency is x, a bit higher than 3000 Hz.
If the bike moves away from you, the frequency is y, a bit lower than 3000 Hz.
x - y = 30 Hz.
Find formulas for x and y and solve the equations, there is no trick involved.
x - y = 30 Hz.
That's what I am doing. I added and subtracted 30Hz.
mfb said:
You used x - 3000 Hz = 30 Hz and 3000 Hz - y = 30 Hz, but that's not right. It would imply x-y = 60 Hz.
So you are saying that 30Hz is the total change in frequency I hear for towards and away. That means that I hear 15 Hz for towards and 15 Hz for away.
If so, then it is 3000-15=2985(away) and 3000+15=3015(towards). Then I just use the equation I used above to get the answer.
That's what the problem statement says.
It is not, the doppler shift is not symmetric.
mfb said:
That's what the problem statement says.It is not, the doppler shift is not symmetric.
I don't think I get it yet. You will need to help me with equations.
mfb said:
All necessary equations are in the thread already, you just have to combine them.
You know what I am trying to tell you. If I had understood what you were trying to tell me, I would have done it by now.
I don't get it.
I don't get it. It's just one question, and I am dedicated enough to waste hours on it. It's certainly not going to make any difference to my overall grade in class if I get it wrong. I am not good at physics, and that is why I am having trouble with this.
No I don't know. The problem got reduced from a problem about the Doppler effect to a topic your classes covered several years ago: plugging in equations and numbers into each other.
You have been telling me to do the same thing over and over, and I don't understand it. You are an expert. And, I appreciate your help.
But, if I am your student in this case, and I am not understanding it, then you should help me with a different approach. Please, help me in a different way.
So would it be 3000-60?
SammyS said:
Definitely not.
Wait! I have a question. When mfb said x-y=30, does he mean that the x and y values are the frequencies the observer hears?
Yes, he is using x and y for frequencies to make a statement about his understanding of the problems statement.
Well this is what @mfb wrote in Post #4.
If the bike moves away from you, the frequency is y, a bit lower than 3000 Hz.​
Okay. I got the idea of what the answer is! Thank you @SammyS
: Towards
vs = 2.18 m/s
You made some error in multiplying (1.01)(343) which is 346.43. This is a huge error b/c if hold off on that multiplication and do some manipulation, you get (1.01)(343) − 343 = (1.01)vs ..
Of course, that left hand side is just (0.01)(343) → 3.43
If you do the AWAY carefully and use 3000 − 30 → 2970 (Hz) , you get a slightly greater bicycle speed .
That confirms the interpretation of the problem given by @mfb .
Take the two frequency equations: towards and away and introduce a way to distinguish the observed TOWARD frequency from the observed AWAY frequency.
## \displaystyle f_{o\,T} = \frac{v+v_o}{v-v_s} \cdot f_s \ \ ## Bike is moving TOWARDS me
## \displaystyle f_{oA} = \frac{v-v_o}{v+v_s} \cdot f_s \ \ ## Bike is moving AWAY from me
Just subtract the second equation from the first, That should give the difference in the two frequencies as pointed out by @mfb . A little trickier Algebra but do-able.
