Find the speed of the source (Doppler Effect)
The discussion revolves around a problem involving the Doppler Effect, specifically related to a scenario where a cyclist rings a bell while approaching and then moving away from an observer. The original poster presents a frequency change of 30 Hz between the two scenarios and seeks to determine the speed of the bicycle based on this information.
  • Participants discuss the interpretation of the frequency shifts when the bicycle approaches and moves away, questioning the correct application of the Doppler equations. There is confusion regarding the total frequency change and how it relates to the individual shifts when approaching and receding.
Several participants have offered insights into the equations and the interpretation of the frequency changes. There is an ongoing exploration of how to correctly apply the Doppler Effect equations to find the speed of the bicycle, with some participants suggesting that the shifts are not symmetric and that the total change must be carefully considered.
Participants note that the original poster may be struggling with the algebra involved in manipulating the equations and understanding the implications of the frequency changes. There is also a recognition that the problem may have been reduced to simpler algebraic manipulation rather than a deeper understanding of the Doppler Effect itself.
mastermind1
A kid is riding a bike and is ringing bell of 3000 Hz. You are standing still on the sidewalk.When the bicycle moves toward you, you hear a shift in the frequency of the bell. In addition, when the bicycle moves away from you, you hear a different shift in the frequency of the bell. If there is a 30 Hz change in the frequencies that you hear for the bell as the bicycle approaches you and then moves away from you, what is the speed (in m/s) of the bicycle? (Write your answer to the nearest 0.01 m/s.)
1. Homework Statement
Frequency(source)(fs) = 3000 Hz
speed(observer)(vo) = 0 m/s
Frequency(towards)(ft)= 3030 Hz (NOT SURE)
Frequency(away)(fa) = 2970 Hz (NOT SURE)
speed of sound(v) = 343 m/s
fo = ((v+vo)/(v-vs)) * fs Bike is moving TOWARDS me
fo = ((v-vo)/(v+vs)) * fs Bike is moving AWAY from me
Towards
3030Hz/3000Hz = (343 m/s) / (343 m/s - vs)
(1.01)(343 m/s - vs) = 343 m/s
345.20 m/s - 1.01 vs = 343 m/s
vs = 2.18 m/s
I do the same thing using the AWAY equation, and i get the same answer.
However, that answer is incorrect. I do not know what I am doing wrong.
The 30 Hz difference are between "towards you" and "away from you". They are not relative to the 3000 Hz.
Could you please elaborate on that. And, give me a hint.
If the bike approaches you, the frequency is x, a bit higher than 3000 Hz.
If the bike moves away from you, the frequency is y, a bit lower than 3000 Hz.
x - y = 30 Hz.
Find formulas for x and y and solve the equations, there is no trick involved.
x - y = 30 Hz.
That's what I am doing. I added and subtracted 30Hz.
You used x - 3000 Hz = 30 Hz and 3000 Hz - y = 30 Hz, but that's not right. It would imply x-y = 60 Hz.
So you are saying that 30Hz is the total change in frequency I hear for towards and away. That means that I hear 15 Hz for towards and 15 Hz for away.
If so, then it is 3000-15=2985(away) and 3000+15=3015(towards). Then I just use the equation I used above to get the answer.
That's what the problem statement says.
It is not, the doppler shift is not symmetric.
mfb said:
That's what the problem statement says.It is not, the doppler shift is not symmetric.
I don't think I get it yet. You will need to help me with equations.
All necessary equations are in the thread already, you just have to combine them.
You know what I am trying to tell you. If I had understood what you were trying to tell me, I would have done it by now.
I don't get it.
I don't get it. It's just one question, and I am dedicated enough to waste hours on it. It's certainly not going to make any difference to my overall grade in class if I get it wrong. I am not good at physics, and that is why I am having trouble with this.
No I don't know. The problem got reduced from a problem about the Doppler effect to a topic your classes covered several years ago: plugging in equations and numbers into each other.
You have been telling me to do the same thing over and over, and I don't understand it. You are an expert. And, I appreciate your help.
But, if I am your student in this case, and I am not understanding it, then you should help me with a different approach. Please, help me in a different way.
There is only one reasonable approach, and I don't know how to explain it differently, sorry.
So would it be 3000-60?
Definitely not.
SammyS said:
Definitely not.
Wait! I have a question. When mfb said x-y=30, does he mean that the x and y values are the frequencies the observer hears?
Yes, he is using x and y for frequencies to make a statement about his understanding of the problems statement.
Well this is what @mfb wrote in Post #4.
If the bike moves away from you, the frequency is y, a bit lower than 3000 Hz.​
Okay. I got the idea of what the answer is! Thank you @SammyS
: Towards
vs = 2.18 m/s
You made some error in multiplying (1.01)(343) which is 346.43. This is a huge error b/c if hold off on that multiplication and do some manipulation, you get (1.01)(343) − 343 = (1.01)vs ..
Of course, that left hand side is just (0.01)(343) → 3.43
If you do the AWAY carefully and use 3000 − 30 → 2970 (Hz) , you get a slightly greater bicycle speed .
That confirms the interpretation of the problem given by @mfb .
Take the two frequency equations: towards and away and introduce a way to distinguish the observed TOWARD frequency from the observed AWAY frequency.
## \displaystyle f_{o\,T} = \frac{v+v_o}{v-v_s} \cdot f_s \ \ ## Bike is moving TOWARDS me
## \displaystyle f_{oA} = \frac{v-v_o}{v+v_s} \cdot f_s \ \ ## Bike is moving AWAY from me
Just subtract the second equation from the first, That should give the difference in the two frequencies as pointed out by @mfb . A little trickier Algebra but do-able.
The thread is from 2015, it is unlikely that OP is still active here.
LOL !
I suppose I saw it in the current list because of the post by @Darious Warren . I didn't pay attention to the date other than Sept.
Oh well, it kept me busy for a while.
