Find the Value of t Using Natural Log for s=18 in s = 0.5(e^t - t - 1)"
The discussion revolves around solving the equation s = 0.5(e^t - t - 1) for t when s is set to 18. Participants are exploring the use of natural logarithms and other mathematical approaches to find the value of t.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Some participants attempt to manipulate the equation using natural logarithms but express confusion over the correct application of logarithmic properties. Others question the existence of solutions and suggest numerical methods or graphing to find approximate values for t.
The discussion is ongoing, with participants sharing various attempts and questioning the validity of their approaches. Some guidance has been offered regarding numerical methods and the Lambert W-function, but there is no consensus on a definitive solution.
Participants note the difficulty of finding an analytical solution and the requirement to show work in the forum. There is also mention of the need to consider only positive solutions for t, as well as the challenge of applying logarithmic rules correctly.
Esas Shakeel
Member warned that an effort must be shown
t=?
when s=18
the use of natural log probably
I tried using the natural log rule but I am getting stuck. Please help me out here. If someone could give a step by step solution,I'll be rreally glad, Cheers
t=?
when s=18
It's a hard forum requirement that you show some work, what you tried, what you thought, etc. Nobody here will write out the entire solution for you.
@Math_QED
18=0.5e^t - t -1
19 = 0.5e^t -t
ln(19) = tln(0.5)-lnt ??
Are you looking for only positive solutions for ##t##? How many solutions do you think there are in total? Make a graph.
It is probably not possible to find an expression for ##t## in terms of standard functions, so you may have to call upon a numerical root finder.
Here, t represents time so if there's a easier way to find only the positive values, then i'd like to know that please :(
There is no solution (positive or otherwise) in terms of elementary functions, so if this is a homework problem that asks you to find an exact solution, you may have to re-read the problem.
If this is indeed the correct equality, then you could proceed to make a graph to get an idea of where the solution may be. Then you can invoke a root finding to determine it approximately.
@Krylov this is the solution. but I am not sure how he got to the value of t :/
Alright sorry i didnt put the bracket. My apologies :p
Esas Shakeel said:
View attachment 107467@Krylov this is the solution. but I am not sure how he got to the value of t :/
No, ##t = 3.7064## does not satisfy ##18 = 0.5(e^t - t - 1)##. (Try it.) It satisfies this equality only approximately and it was probably found using a numerical root finder or by reading it off from a sufficiently detailed graph.
What the heck?! I've wasted pages just to get the answer but i couldnt. I'll sue the author for this! lol . I'll take this question to my dynamics teacher and see what he comes up with. Thanks man! @Krylov
You can't solve <br /> e^t - t = 37 analytically; if you have a calculator, then the iteration <br /> t_{n+1} = \ln(t_n + 37) with t_1 = 0 converges rapidly to t = 3.706384959 to the precision my calculator will display. (How did I know to try that instead of <br /> t_{n+1} = e^{t_n} - 37? For the iteration t_{n+1} = f(t_n) to converge to a solution of t = f(t) which you know to exist then you must have |f&#039;(t)| &lt; 1 near that solution. \ln(t + 37) has derivative 0 &lt; 1/(t + 37) &lt; 1 for all t &gt; 0; e^t - 37 has derivative e^t &gt; 1 for all t &gt; 0.)
Esas Shakeel said:
@Math_QED
18=0.5e^t - t -1
19 = 0.5e^t -t
No, absolutely NOT.
$$\ln(0.5 e^t - t) \neq t \ln(0.5) - \ln(t)$$.
Never, ever write $$\ln(a \pm b) = \ln(a) \pm \ln(b) \; \Longleftarrow \; \text{FALSE!}$$
The correct property of logarithms is
$$ \ln(a \times b) = \ln(a) + \ln(b)\; \Longleftarrow \; \text{True!}$$
Anyway, this problem has no solution in elementary functions, but it can be solved in terms of the so-called Lambert W-function. That is a decidedly non-elementary function, whose evaluation will not appear on any calculator button and probably not even in any spreadsheet.
It is probably easiest to just look for a numerical solution using one of the many numerical root-finding methods available.
But i just used the natural log power rule
ln(x^y) = y ∙ ln(x)
how can that be wrong?
@Ray Vickson
ln(x^y) = y ∙ ln(x)
@Ray Vickson
No, you did not; I was responding to your post where you wrote
19 = 0.5e^t -t
That was a "cut and paste" of your actual writing.
Basically, you were saying that ##\ln(.5 e^t -t) = \ln(0.5 e^t) - \ln(t)##, which is definitely wrong.
Noted.
@Ray Vickson
Oh i get it! Yeah you're right. Natural log really confuses me even though I am well aware of the existence of these simple rules :p
