Find the value of x^5 + y^5 + z^5.
  • Context: MHB
  • Thread starter Thread starter anemone
    Value
The discussion revolves around finding the value of \(x^5 + y^5 + z^5\) given a system of equations involving \(x\), \(y\), and \(z\). The problem is approached through various methods, including Newton's identities and algebraic manipulation, with participants sharing their solutions and challenges.
  • One participant proposes using Newton's identities to derive the value of \(x^5 + y^5 + z^5\) and arrives at a solution of \(83\).
  • Another participant expresses uncertainty about their lengthy and complex method, which leads to a different answer, suggesting they may have made an error.
  • This participant outlines their approach, involving multiple algebraic manipulations and substitutions, ultimately yielding a complicated expression for \(x^5 + y^5 + z^5\).
  • Several participants commend the effort and tenacity of those who worked through their methods, regardless of the perceived correctness of their solutions.
  • There is acknowledgment of the complexity of the symbols and methods used, indicating a potential barrier to understanding for some participants.
Participants do not reach a consensus on the correct value of \(x^5 + y^5 + z^5\). There are competing methods and results, with one method yielding \(83\) and another leading to a more complex expression. The discussion remains unresolved regarding the correctness of the different approaches.
Participants express uncertainty about specific steps in their calculations, and there are indications of missing assumptions or potential errors in reasoning. The complexity of the algebra involved may contribute to the lack of clarity in the solutions presented.
This discussion may be useful for individuals interested in advanced algebraic techniques, Newton's identities, and problem-solving strategies in mathematical contexts.
anemone
MHB
POTW Director
Knowing that the system
$x+y+z=3$
$x^3+y^3+z^3=15$
$x^4+y^4+z^4=35$
has a real solution x, y, and z for which $x^2+y^2+z^2<10$, find the value of $x^5+y^5+z^5$ for that solution.
Hi all,
I found this problem very interesting and wanted to post it here as one of the challenging problem and I have solved it and am looking forward to seeing your method and solution too.
I will post my solution in a few days, so that everyone interested can have a chance to demonstrate how they would solve it.
anemone
Mathematics news on Phys.org
Re: Find the value of x^5+y^5+z^5.
$x+y+z=3$
$x^3+y^3+z^3=15$
$x^4+y^4+z^4=35$
Hi all,
anemone
I used Newton's identities to solve this problem. Let $\lambda^3 -a\lambda^2+b\lambda-c=0$ be the equation whose solutions are $x,\ y$ and $z$, and let $p_k = x^k+y^k+z^k$, for $k=1,2,3,\ldots$. Newton's identities say that $$\begin{aligned}a &= p_1 \\ 2b &= ap_1-p_2 \\ 3c &= bp_1-ap_2 + p_3 \\ 0 &= cp_1-bp_2+ap_3 - p_4 \\ 0 &= 0p_1 - cp_2 + bp_3-ap_4 + p_5 .\end{aligned}$$ Inserting the values that we are given, the first four identities become $$\begin{aligned}a &= 3 \\ 2b &= 9-p_2 \\ 3c &= 3b-3p_2 + 15 \\ 0 &= 3c-bp_2+45 - 35 .\end{aligned}$$ Substitute the values for $b$ and $c$ from the second and third of these equations into the final one, we get $$0 = \tfrac32(9-p_2) - 3p_2 + 15 - \tfrac12(9-p_2)p_2 + 10 = \tfrac12(p_2^2 - 18p_2 + 77) = \tfrac12(p_2-7)(p_2-11).$$ That gives possible values of $7$ or $11$ for $p_2$. But we are told that $p_2<10$, so we must have $p_2=7.$
Substituting that value for $p_2$ it is easy to check that $b=1$, $c=-1$, and then the last of the Newton identities above gives $\boxed{p_5 = 83}.$
[The cubic equation in $\lambda$ then becomes $\lambda^3 -3\lambda^2+\lambda+1=0$, which has solutions $\lambda = 1$ and $\lambda = 1\pm\sqrt2.$ So those are the values of $x$, $y$ and $z$.]
Awesome!
I used an elementary method to solve it because I don't know anything about the Newton Identities, and you can expect my solution to be lengthy and tedious. But, my answer is different from yours and I am certain that it must be my answer that is wrong.
Could you please tell me where did I do wrong?
Here is my solution:
We're told that
$x+y+z=3$
$\therefore (x+y+z)^2=3^2=(x+y+z)(x+y+z)=x^2+y^2+z^2+2(xy+yz+xz)$
We get
$9=x^2+y^2+z^2+2(xy+yz+xz)$---(1)
Now, we cube the expression $x+y+z$, we get:
$(x+y+z)^3=3^3=x^3+y^3+z^3+3x^2y+3x^2z+3xy^2+3xz^2+3y^2z+3yz^2+6xyz$
$12=3y(x^2+z^2)+3z(x^2+y^2)+3x(y^2+z^2)+6xyz$
Rearrange it and do some algebraic trick, the equation above becomes:
$12=3y(x^2+z^2+y^2-y^2)+3z(x^2+y^2+z^2-z^2)+3x(y^2+z^2+x^2-x^2)+6xyz$
$12=3y(x^2+z^2+y^2)-3y^3+3z(x^2+y^2+z^2)-3z^3+3x(y^2+z^2+x^2)-3x^2+6xyz$
$12=3(x^2+y^2+z^2)(x+y+z)-3(x^3+y^3+z^3)+6xyz$
$12=3(x^2+y^2+z^2)(3)-3(15)+6xyz$
$57=9(x^2+y^2+z^2)+6xyz$
$19=3(x^2+y^2+z^2)+2xyz$---(2)
Similarly, we raise the equation $x+y+z$ to the fourth power yields
$(x+y+z)^4=3^4=x^4+y^4+z^4+4x^3y+4xy^3+4xy^3+4xz^3+4yz^3+6x^2y^2+6x^2z^2+6y^2x^2$
$81=35+4x^3y+4xy^3+4xy^3+4xz^3+4yz^3+6x^2y^2+6x^2z^2+6y^2x^2$
$46=4y(x^3+z^3)+4z(x^3+y^3)+4x(y^3+z^3)+6(x^2y^2+x^2z^2+y^2z^2)$
$46=4y(x^3+z^3+y^3-y^3)+4z(x^3+y^3+z^3-z^3)+4x(y^3+z^3+x^3-x^3)+6(x^2y^2+x^2z^2+y^2z^2)$
$46=4(x^3+z^3+y^3)(x+y+z)-4(x^4+y^4+z^4)+6(x^2y^2+x^2z^2+y^2z^2)$
$46=4(15)(3)-4(35)+6(x^2y^2+x^2z^2+y^2z^2)$
$6=6(x^2y^2+x^2z^2+y^2z^2)$
$1=x^2y^2+x^2z^2+y^2z^2$---(3)
From (1) and (2), we get:
$19=3(9-2(xy+yz+xz))+2xyz$
$19=27-6(xy+yz+xz)+2xyz$
$6(xy+yz+xz)=8+2xyz$
$3(xy+yz+xz)=4+xyz$---(4)
Next, we square the expression $xy+yz+xz$ and obtain:
$(xy+yz+xz)^2=x^2y^2+y^2z^2+x^2z^2+xy^2z+x^2yz+xy^2z+xyz^2+x^2yz+xyz^2$
$(xy+yz+xz)^2=(x^2y^2+y^2z^2+x^2z^2)+2xy^2z+2x^2yz+2xyz^2$
$(xy+yz+xz)^2=(x^2y^2+y^2z^2+x^2z^2)+2xyz(x+y+z)$
$\therefore (xy+yz+xz)^2=1+6xyz$ since $x^2y^2+x^2z^2+y^2z^2=1$
From (4) and the equation above, we could further simplify them to get
$9(xy+yz+xz)^2=(4+xyz)^2$
$9(1+6xyz)=16+8xyz+(xyz)^2$
$9+54xyz=16+8xyz+(xyz)^2$
$(xyz)^2-46xyz+7=0$
$\displaystyle xyz=23 \pm 3\sqrt{58}$ (This doesn't seem right...)
Since $x^2+y^2+z^2<10$, $\displaystyle xyz=23 - 3\sqrt{58}$.
Finally, we raise the equation $x+y+z$ to the fifth power, this gives
$(x+y+z)^5=3^5=x^5+y^5+z^5+5x^4y+5x^4z+5xy^4+5xz^4+5y^4z+5yz^4$
$+10x^3y^2+10x^3z^2+10x^2y^3+10x^2z^3+10y^3z^2+10y^2z^3+20xyz(x^2+y^2+z^2)+30xyz(xy+yz+zx)$
$3^5=-14(x^5+y^5+z^5)+5(x^4+y^4+z^4)(x+y+z)+10(x^3+y^3+z^3)(x^2+y^2+z^2)$
$+20xyz(x^2+y^2+z^2)+30xyz(xy+xz+yz)$
$3^5=-14(x^5+y^5+z^5)+5(35)(3)+10(15)(x^2+y^2+z^2)+20xyz(x^2+y^2+z^2)+30xyz(xy+xz+yz)$
$3^5=-14(x^5+y^5+z^5)+5(35)(3)+150(x^2+y^2+z^2)+20xyz(x^2+y^2+z^2)+30xyz(xy+xz+yz)$
$3^5=-14(x^5+y^5+z^5)+5(35)(3)+(x^2+y^2+z^2)(150+20xyz)+30xyz(xy+xz+yz)$
$3^5=-14(x^5+y^5+z^5)+5(35)(3)+\left(\frac{19-2xyz}{3}\right)(150+20xyz)+30xyz\left(\frac{4xyz}{3}\right)$
By substituting the value of $\displaystyle xyz=23 - 3\sqrt{58}$ into the equation above, we get
$x^5+y^5+z^5=\frac{-2214+780\sqrt{58}}{42}$
I am aware that this is just way too tiring to even look at,(Tmi) never mind, Opalg, I will use the Newton Identities instead, thanks for participating in this particular problem.:)
Thanks.
The symbols... they confuse me...
Congratulations for sticking with your method to the bitter end though Anemone. I shamefully admit I probably would've thrown the whole thing out of the window a third of the way through and looked for an easier way (Smoking)​
By the way, you can use \tag{some number} in LaTeX to number your equations :)
Yes, I too must applaud your tenacity...and willingness to share your work even though you believe it to be incorrect. Most would have run for the hills, tail tucked...myself included! (Rofl)
That's so nice of you to say so, Bacterius..
I see...I don't realize that. I'll keep this in mind! Thanks!
Hey Mark, it was you who encouraged me to post the silliest solution of mine here, hehehe...
I may have given you a nudge, but you were the one that made the final decision. (Yes)
We're told that
$x+y+z=3$
We get
Everything is correct up to here!
That is where it goes wrong. The expansion of $\color{red}{(x+y+z)^4}$ should be
$\color{red}{ x^4+y^4+z^4 + 4x^3y+4xy^3+4x^3z+4xz^3+4y^3z+4yz^3 +6x^2y^2+6x^2z^2+6y^2z^2 + 12x^2yz+12xy^2z+12xyz^2}.$
As you can see, things get very complicated when you raise a trinomial to a large power! That is why the Newton identities are so useful. They save you from having to make very long calculations by splitting them into manageable steps.
In fact if students have no idea about Newton's identities they can still solve this problem, in a similar way like Opalg did (very innovative (Yes))
Thanks for pointing this out for me, Opalg!:) I couldn't believe that I made such a silly mistake while multiplying out the trinomials.(Headbang):mad:
Now, I agree wholeheartedly that Newton identities are very useful and it's never too late to learn a new concept in maths, I guess.:o
