How to Find a Unit Vector in the Direction of a Given Vector
  • Thread starter Thread starter chocolatelover
    Vector
The discussion focuses on finding a unit vector in the direction of the vector w = -i - 2j. The magnitude of this vector is established as √5. To obtain the unit vector, participants confirm that the correct calculation involves dividing the vector w by its magnitude, resulting in the unit vector being (-i - 2j)/√5. The conversation also touches on graphical representation using an Argand diagram, emphasizing the importance of understanding both algebraic and graphical methods in vector analysis.
  • Understanding of vector notation and components
  • Knowledge of vector magnitude calculation
  • Familiarity with unit vectors and their properties
  • Basic concepts of Argand diagrams
  • Study vector normalization techniques in 2D space
  • Explore graphical representations of vectors using Argand diagrams
  • Learn about the properties of unit vectors in different dimensions
  • Investigate applications of unit vectors in physics and engineering
Students studying linear algebra, mathematics enthusiasts, and anyone seeking to understand vector analysis and its applications in various fields.
chocolatelover
Find a unit vector in the direction of the given vector w=-i-2j
-i
_______
vertical -2j_________________
Could someone please show me how I would do it grafically and algebraically?
Do I just need to find the magnitude? Wouldn't any vector that has a negative x component and a negative y component work?
square root (-1)^2+(-2)^2=square root 5
Thank you very much
Any vector A divided by magnitude of A is a unit vector.
I haven't studied this in quite a while, but have you tried representing it with an Argand diagram?
http://scholar.hw.ac.uk/site/maths/topic11.asp?outline=
Thank you very much
Isn't the magnitude, in this case, the square root of 5?
So, would the unit vector be 1/square root of 5i? Aren't i and j the unit vectors? I'm already given the unit vectors, right? Don't I just need to find another one in the same direction?:confused:
Thank you
Well I had a quick check of old material, but the modulus of an Argand diagram or distance from 0 is the magnitude.
if z=x+yi then |z|=\sqrt{x^2+y^2}.
http://www.clarku.edu/~djoyce/complex/abs.html
And then.
Like I say it's been a while but hope that helps.
Some straight answers …
No-one gives you a straight answer, do they? :smile:
Yes, the magnitude is √5. (btw, type alt-v and it gives you √)
No, you mean the unit vector is (-i - 2j)/√5.
Yes, i and j are always unit vectors in this sort of question.
Yes, you're right. Why so puzzled?
No - I don't see why you'd think that. :confused:
graphically and algebraically?
Algebraically, you've understood it fine!
Graphically: -i -2j is on the circle of radius √5; join it to the origin by a line; then you want the point where that line cuts the circle of radius 1. :smile:
Thank you very much everyone
Regards
Right.
i and j are unit vectors along the positive x-axis and y-axis respectively, but you can find a unit vector in any direction. In this case, the given direction was along the vector w=-i-2j. So, you have to divide w by mod(w) to get the unit vector in the direction of w.
You got that right. :biggrin: Everybody wants to make sure the OP does learn a bit at least by doing something himself/herself.
Including me, I just learned how to calculate the magnitude of a vector using an Argand diagram. Again. :smile:
  • · Replies 44 ·
  • · Replies 16 ·
