Find the Wavelengths of Compton Scattered Photon and Original Photon
The discussion focuses on solving a Compton scattering problem involving a photon scattered at a 90-degree angle and an electron moving at a 20-degree angle. The key equation used is Δλ = (h/mc)(1 - Cosθ), which relates the change in wavelength to the scattering angle. Participants emphasize the importance of applying conservation of momentum and energy principles to derive the wavelengths of both the original and scattered photons. The conversation highlights the need to clarify the definitions of relativistic momentum and rest energy to successfully solve the problem.
  • Understanding of Compton scattering and its equations
  • Familiarity with conservation of momentum and energy principles
  • Knowledge of relativistic momentum and rest energy concepts
  • Ability to manipulate trigonometric functions in physics equations
  • Review the derivation of the Compton wavelength shift formula
  • Study the principles of relativistic momentum and energy conservation
  • Learn how to apply trigonometric functions in physics problems
  • Explore examples of Compton scattering problems for practical understanding
Physics students, educators, and anyone interested in understanding the principles of Compton scattering and relativistic effects in particle physics.
majinsock
Okay, so here's the problem:
In a Compton scattering experiment, a photon is scattered through an angle of 90.0 and the
electron is set into motion in a direction at an angle of 20.0 to the original direction of the
photon.
(a) Explain how this information is sucient to determine uniquely the wavelength of the
scattered photon.
(b) Find this wavelength.
λ2 - λ1 = (h/m c)(1 - Cosθ)
So, with the angle I'm given I can find Δλ, but I won't be able to find λ2 which is what I believe the question is asking me to find. I feel like I should be using the angle of the electron but I don't really see how I can. Can anyone help me out here? :S
Write the x and y component equations for momentum conservation:
For x, the photon has initial momentum h/λ1 and final momentum is a function of p, scattered electron angle ψ, scattered photon angle θ (actually a new photon!), and λ2. p is the scalar relativistic momentum of the electron after collision so the x component of momentum for the electron would be p*cosψ.
Similarly, for the y direction, you have 0 = a function of p, the same two angles, and λ2.
On top of that you also need to invoke energy conservation: initial photon energy plus electron rest energy = new photon energy plus relativistic electron energy which of course is E = √[(pc)2 + E02].
3 equations, 3 unknowns: λ1, λ2 and p.
Well, I'm screwed. Thanks, though.
Why? It's just basic momentum & energy conservation, and I think I gave you most of the relativistic stuff you need.
I have a vague idea of what I'm supposed to be doing but I'm just so horrible at this.
Ok, here's my attempt:
The initial momentum of the photon in the x direction PLUS the initial momentum of the electron in the x direction (would it be zero??) has to equal the sum of both final x direction momentums.
Sooooooooo
Ppix (Momentum photon inital x direction) = h/λ1
Peix (momentum electron initial x direction) = 0?
Ppfx = I have no idea
Pefx = p Cosψ (what is p exactly? Scalar Relativistic momentum? What does that mean?)
So Ppix + Peix = Ppfx +Pefx
And likewise with the y components, although I wouldn't have the first clue where to start with that
And energy. Hmmmmmm. So...
h f1 + electron rest energy = h f2 + √[(pc)^2 + E0^2]
Huh. What's E0? What's electron rest energy? What exactly is this "p"?! Yeah, I'm in bad shape right now :/
Check.
Sooooooooo
Ppix (Momentum photon inital x direction) = h/λ1 Right.
Peix (momentum electron initial x direction) = 0? Right!
C'mon - what is the magnitude of the new photon momentum - you got the right expression for the incoming one - but now take just the x component? [/color]
p = mv and m is the relativistic mass. Remember how m is corrected for relativistic motion? You should review this area.
So Ppix + Peix = Ppfx +Pefx Right.
Is there a y component of initial momentum for either the electron or the photon? As for the final, for the electron, it's going to be p times the sin of ψ, right? With a - sign since ψ is negative if you draw a picture of the "after" situation. And I know you know the new photon's momentum, but again taking just the y component.
? Exactly!
Yeah, you need to review. Relativisically, rest energy derives from the special theory which exchanges energy for mass, and you know the electron has mass ...
Ok, so would the new x component momentum for the photon be h/λ2 * Cosθ? Or is there something I'm missing?
And would the initial y components for the photon and electron be zero?
As for the final y components would they be:
Ppfy= h/λ2 * sinθ?
Pefy= p sinψ?
So, in total:
h/λ1 + 0 = h/λ2 * cosθ + p cosψ <------x components
0 = h/λ2 * sinθ + p sinψ ---> -p sinψ = h/λ2 * sinθ <--------y components
But that's assuming that I got the final x and y components right
And for energy:
hc/λ1 + mc^2 = hc/λ2 + √[(pc)^2 + E0^2] ?
I'm not totally sure how to get the last part. Is E0 rest energy?
I really do need to review this stuff. Can you let me know if this is right? And I apologize for saying that I was screwed. That was pretty immature of me. I just get so dang frustrated with this stuff!
majinsock said:
Ok, so would the new x component momentum for the photon be h/λ2 * Cosθ? Or is there something I'm missing? Right.
And would the initial y components for the photon and electron be zero? Right!
Ppfy= h/λ2 * sinθ? Yes!
Pefy= p sinψ? Almost. What did I say about the sign having to be negative? Do you see why? Draw a picture of the trajectories of the final photon & electron motion.
So, in total:
Fix the sign of p sinψ
And for energy:
mc^2 is not the rest energy. E0 = m0c2 is. mc^2 is the total energy = rest energy + kinetic energy. m is always the relativistic energy. Replace your mc^2 with E0 =m0c^2.
So now you see that you can solve for λ1 and λ2, right? Which is what the question seemingly asks for.
  • Sticky
