Find v and x of electron in an electromagnetic wave
The discussion revolves around finding the velocity (v) and position (x) of an electron in an electromagnetic wave, specifically through the integration of a differential equation related to the force acting on the electron.
  • Participants discuss the integration of the equation dv/dt = -qE/m(sin(ωt+φ)) to find v as a function of time, and subsequently x as a function of time. Questions arise about the integration process, particularly regarding the integration of sin(ωt+φ) and the application of the chain rule.
The discussion is ongoing, with participants exploring the integration of trigonometric functions and questioning assumptions about constants and variables involved. Some guidance has been offered regarding the derivative of cosine functions and the implications of initial conditions on the constant of integration.
Participants note the electron's initial state of rest, which may influence the integration constants. There are also references to the need for foundational knowledge in algebra and calculus to fully engage with the problem.
everyall
Thread moved from the technical Math forums, and OP is reminded to show their work on their schoolwork questions
When
dv/dt= -qE/m(sin(ωt+φ))
Find v
Then x
By integrating
everyall said:
When
Find v
Then x
By integrating
Well, if you have dv/dt, then integrate it to get v as a function of t. Then v = dx/dt. Integrate that to get x as a function of t.
Is your question how to integrate this?
-Dan
-Dan
Yes i like to know how to integrate (sin(ωt+φ))dt
Do you know what the primitive function of sin(t) is?
Do you mean ∫sin(t) = -cos(t)
+C
Ok. Next. What is the derivative of ##-\cos(\omega t + \varphi )## with respect to ##t##?
malawi_glenn said:
+C
I don't know this because it has 2 variable
##-\omega t and \varphi##
Which is plus inside sin function
How to solve this
  • Sad
No ##\omega## is constant pretend that is has value say 2.78 or whatever
Did you not learn about the chain rule in school?
I still don't know how to integrate sin(a+b)
That sucks. Just google it. Chain rule of differentiation
I found dy/dx=dy/du*du/dx
Does it mean pretend wt+phi =u ?
Then what is the result after intregrate
From text , i like to know where -eE/mw(cosphi) come ?
Is it should be C instead after integrate sin(wt+phi)
yes
Well figure out what the derivative of ##-\cos(\omega t + \varphi)## is then it should be pretty easy to figure out what the primitive function to ## \sin(\omega t + \varphi)## is.
Out of curiousity, why are you doing this problem if you have not taken approriate math classes?
The problem says that the electron is initially at rest, so you can determine the value of the constant of integration C.
malawi_glenn said:
yes
Out of curiousity, why are you doing this problem if you have not taken approriate math classes?The problem says that the electron is initially at rest, so you can determine the value of the constant of integration C.
I try to understand physics to discover some new things at 42 year old with high school knowledge.
Thanks
Thanks
You will discover more if you spend some time doing basic algebra and calculus first. The language of physics is math.
malawi_glenn said:
yes
Diff -cos(wt+phi) = wsin(wt+phi)
Where this term come from
I wrote it earlier in this thread.
## \dfrac{\text d v}{\text d t} = - \dfrac{eE_0}{m}\sin (\omega t - \varphi)##
You now know that the derivative of ##-\cos (\omega t - \varphi) ## is ## \omega \sin (\omega t - \varphi)##
Then you also know this, that the derivative of ##-\dfrac{1}{\omega}\cos (\omega t - \varphi) ## is ## \sin (\omega t - \varphi)##
It should not too hard to figure out what ##v(t)## is now.
  • · Replies 22 ·
