Finding a limit using power series expansion
The discussion revolves around finding the limit of the expression (1/x^2) * (cos x / (sin x)^2) as x approaches 0 using power series expansion. The initial approach led to a 0/0 form, prompting the use of L'Hôpital's rule and power series for sine and cosine. A critical error was identified in the expansion of sin^2(x), which was incorrectly squared, leading to an incorrect limit calculation of 1/2 instead of the expected 1/6. Clarification was provided that the problem statement likely intended a different formulation, suggesting the limit should be approached as (1/x^2) - (cos x / (sin^2 x)). This highlights the importance of accurately interpreting mathematical expressions in limit problems.
Daniel Lobo
The problem wants me to find the limit below using series expansion.
##\lim_{x \to 0}(\frac{1}{x^2}\cdot \frac{\cos x}{(\sin x)^2})##
(1) For startes I'll group the two fractions inside the limit together
##\lim_{x \to0}\frac{sin^2(x)-x^2cos(x)}{x^2sin^2(x)}##[/B]
This limit is of the form 0/0 so I can use l'hopital's rule here, I'll expand both the numerator and the denominator into their respective power series and take enough derivatives so that the functions don't equal to zero at x=0.
(2) The numerator expanded:
##sin^2(x)-x^2cos(x)=\sum_{n=0}^\infty\frac{x^{4n+2}}{((2n+1)!)^2}-\sum_{n=0}^\infty\frac{(-1)^{n}x^{2n+2}}{(2n)!}=(x^2+\frac{x^6}{36}+...)-(x^2-\frac{x^4}{2}+...)=(\frac{x^4}{2}+\frac{x^6}{36}+...)##
(3) The x^(4)/2 is the only part of interest to me since it's the only part that will not be zero after taking 4 derivatives and setting x=0 and doing so will wield:
##\frac{\mathrm{d^4} }{\mathrm{d} x^4}(sin^2(x)-x^2cos(x))|_{x=0}=12##
The denominator expanded:
##x^2sin^2(x)=\sum_{n=0}^\infty\frac{x^{4n+4}}{(2n+1)^2!}=(x^4+\frac{x^8}{4}+...)##
(4) Doing the same as in (3):
##\frac{\mathrm{d^4} }{\mathrm{d} x^4}(x^2sin^2(x))|_{x=0}=24##
With these results I reach my answer of 12/24=1/2 but my book says the answer is 1/6 and I can't figure out what I'm doing wrong for the life of me, it's been 3 hours on this exercise already and would really apreciate some advice. Also apologies for the iffy english.
The operator in the problem statement is the \cdot operator; that means multiplication, not subtraction.
##\frac{\mathrm{d^4} }{\mathrm{d} x^4}(sin^2(x)-x^2cos(x))|_{x=0}=12##The denominator expanded:
Your task is greatly eased by means of the identity <br /> \sin^2 x = \tfrac12(1 - \cos 2x) which eliminates the need to square the series for sine, which you have done incorrectly. The square of \sum_{n=0}^\infty a_nx^n is <br /> \sum_{n=0}^\infty \sum_{m=0}^\infty a_na_mx^{n+m} = \sum_{n=0}^\infty \left(\sum_{k = 0}^n a_k a_{n-k}\right) x^n and not <br /> \sum_{n=0}^\infty a_n^2 x^{2n} as you have.
Thank you I understand where I made my mistake in assuming the sin²x expansion, and \cdot operator is seems to have gone unnoticed. Thanks again.
##\displaystyle \lim_{x \to0}\frac{sin^2(x)-x^2cos(x)}{x^2sin^2(x)}##[/B]
There appears to be an error in your statement of the problem. If the problem is as you state it, then the limit is ∞. Not that difficult to show.
Judging by that next equation it appears that the problem statement should be:
Find the limit using series expansion.
##\displaystyle \lim_{x \to 0}\left(\frac{1}{x^2}-\frac{\cos x}{\sin^2x}\right)##​
Use the expression for sin2(x) given by pasmith, then use the expansion for cosine:
##\displaystyle \cos(x)=1-\frac{x^2}{2}+\frac{x^4}{4!}-\dots ##​
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
