Finding a nonzero vector for the homogeneous system
8 replies · 3K views · last reply
dmitriylm
1. Express the general solution of the following system in vector form.
2x + 4y + 6z + 4w = 4
2x + 5y + 7z + 6w = 3
2x + 3y + 5z + 2w = 5
Clearly identify the particular solution. Also produce a vector with no zero components that satisfies the corresponding homogeneous system.
The solved echelon form is:
0x + 1y + 1z + 2w = -1
x = 4 + 2w -z
y = -1 - z - 2w
solution set: (4-z+2w, -1-z-2w, z, w)
The solution in vector form is displayed as:x |0 | |4 | | -1 | | 2|
y = |0 |+ |-1|+ | -1 |z + | 2|w
z |0 | |0 | | 1 | | 0|
w |0 | |0 | | 0 | | 1|The particular solution is the vector:
|4 |
|-1|
|0 |
|0 |
What I'm confused by is this statement: "Also produce a vector with no zero components that satisfies the corresponding homogeneous system.". What is the corresponding homogeneous system? How do I find it? How do I then produce this vector with no zero components?
You have a system of equations that is M x = f, where M is a matrix and x, f are vectors. The homogeneous system is M x = 0.
So how do I take the solutions that I have to show a homogeneous system? My equations do not equal to zero. Is there a conversion process to do this?
The corresponding homogeneous system is just
2x + 4y + 6z + 4w = 0
2x + 5y + 7z + 6w = 0
2x + 3y + 5z + 2w = 0
You can solve this by using the same techniques as for the inhomogeneous system.
fzero said:
The corresponding homogeneous system is just2x + 4y + 6z + 4w = 0
What process did you use to arrive at this equation set? I'd like to do so on my own. Thanks for the help!
*edit* I see that you simply took all of the solutions and replaced them with zero's.
Yes, as I said before, given a vector x of unknowns and a matrix A of coefficients, you can write the linear system
A x = 0.
Because of the 0 vector on the RHS, this is called a homogenous equation. Technically the reason for the terminology is that the equation is invariant under a rescaling of x by a scalar multiple t,
A (t x) = t ( A x ) = t 0= 0.
If we are given an additional vector y, we can construct the inhomogenous system
A x = y.
So solving for that homogeneous system produces the following result:
2 4 6 4 = 0
0 1 1 2 = 0
0 0 0 0 = 0
with x=-z+2w and y=-z-2w, solution set is (-z+2w, -z-2w, z, w)
and a solution vector of:
Which is not what the problem is asking for. How do I find a solution vector that has no zero components? Is this even possible if the solutions for a homogeneous system of equations are zero's by definition?
fzero said:
z and w don't have to be zero.
Ah! That's right! I can just make them any number, and then add the resulting vectors together correct? Thank you so much!
Would I right that as such? :
when z=w=1;
solution vector:
