Finding a side length in similar triangles?
  • Thread starter Thread starter moonman239
    Length Triangles
Triangle ABD is similar to triangle ABC due to the congruence of angles B and C, with the sum of angles ADB and BDC equaling 180 degrees. The similarity ratio is established as 4:16 based on the known side lengths AD and DC. However, the user is unable to determine the length of side AB without knowing at least one side length from triangle ABC. A suggestion is made to provide a screenshot or sketch of the triangles for better clarity. Understanding the properties of similar triangles is essential for solving the problem effectively.
moonman239
Side note: PF is awesome! This is kind of like Tutor.com, only it's free and others can contribute their answers.
Explain why triangle ABD is similar to triangle ABC and then find the length of side AB. Angles B and C are congruent. m(ADB)+m(BDC) = 180 degrees. AD=4 and DC=12.
2. Relevant theorems, postulates, properties, etc.
Corresponding parts of similar angles are similar.
Symmetric property of similarity - if XYZ is similar to ABC, then XZY is similar to ACB, ZXY is similar to CAB, etc.
The similarity ratio is 4:16 (side length in ABD:side length in ABC).I know that. If I knew at least one side length I could easily figure out what AB is. The problem is I don't.
It would be helpful if you could post a screen shot or sketch of the two triangles.
  • · Replies 27 ·
