Calculating Tension Ratio in Inelastic Collision of Hanging Clay Balls
  • Thread starter Thread starter Gman24
    Ratio Tension
The discussion focuses on calculating the tension ratio (T2/T1) in an inelastic collision involving two clay balls, where one ball of mass m hangs from a string of length L, and a second ball of mass 2m approaches with a speed of sqrt(2gL). The solution involves applying conservation of momentum and energy principles, leading to the conclusion that the tension ratio T2/T1 equals 5/17. Key equations utilized include momentum conservation (m1V1 + m2V2 = (m1 + m2)Vimp) and energy conservation (E1 + Work Non Conservative = E2).
  • Understanding of inelastic collisions
  • Familiarity with conservation of momentum and energy principles
  • Knowledge of free body diagrams (FBDs)
  • Basic trigonometry for analyzing angles in physics
  • Study the principles of inelastic collisions in detail
  • Learn about free body diagram analysis for complex systems
  • Explore energy conservation in mechanical systems
  • Investigate the effects of tension in strings during dynamic motion
This discussion is beneficial for physics students, educators, and anyone preparing for exams involving mechanics, particularly inelastic collisions and tension analysis in systems involving strings and pendulums.
Gman24
A clay ball of mass m hangs from a string with length L. When a second clay ball with mass 2m approaches it with a speed of sqrt(2gL) on the same plane. The collision is completely intelastic so that the balls stick together after the collision. Let T1 be ethe tension in the string immediately after the collision and T2 be the tension in the string when the combined balls are at their maximum angle X. Find T2/T1.
The known quantities are m, g, and L
the answer is supposed to be : 5/17
m1V1+m2V2=(m1+m2)Vimp
E1 + Work Non Conservative= E2
any Force summations
ok so I started out with momentum conservation.
since the mass m is at rest I threw that out of the left side of the eqn.
so I get:
2m(rt[2gL]) = (3m)Vimp
so I conlculded that the impact velocity (Vimp)= 2/3of(rt[2gl])
I then did FBDs for the initial and at the top of the swing.
at the bottom I got that
T1-3mg = (3mVimp/L)
T2-3mgcosX = 0 (im not sure about this but I don't think it's accelerating radially if it hits absolute max swing angle since it would be at rest would it not at that instance?"
I then did energy conservation:
E1+Wnc=E2
I defined my y=0 to be the plain that the initial balls were traveling in. I got the ff:
E1 + Wnc:
K=(1/2)3mVimp^2
U=0
W=T1Lcos0 (again not sure)
E2:
K=0
U= 3mg(L-LcosX)
I don't know how to approach the problem given what I've found out. Thank you soo much for your guys' help in advance. Oh and sorry for the crazy notation I am using. I've had to make some compromises since I don't know how to do greek lettering and such on the comp :).
sorry for the double post but I don't know if this will help but here is the visual. Its problem number 2 on my practice test. Thanks again
anybody? I really need help on this one. I have a test in 2 hours.
11K
