How Do You Calculate Acceleration on an Inclined Plane with Friction?
To calculate acceleration on an inclined plane with friction, the relevant equation is gsinθ - ugcosθ = a, where g is gravitational acceleration, θ is the angle of incline, and u is the coefficient of friction. The box starts sliding at an angle of 36.8699 degrees, with a coefficient of kinetic friction of 0.4, leading to a calculated static friction coefficient of 0.75. The user attempted to solve for acceleration but received a different answer than the expected 2.744, indicating a misunderstanding of the friction type applicable once the box is in motion. It is crucial to differentiate between static and kinetic friction when analyzing the problem. Understanding these concepts will help clarify the calculations involved.
alex_todd
he question is:
A box is sitting on a board. The coefficient of kinetic friction between the box and the board is 0.4. One side of the board is raised so that the board is 36.8699 degrees from horizontal. This is the angle that the box starts sliding.There are two parts to the question, I figured out part A (What is the coefficient of static friction between the box and the board?) by setting Mk equal to Tan and got .75
The part that throws me off about this equation is the last sentence " This is the angle that the box starts sliding"
I'm pretty sure that if it weren't for that, I would use the equation gsinθ - ugcosθ = a however I tried that and didn't get the right answer
mgsinθ - umgcosθ = ma
gsinθ - ugcosθ = a
mk=tan theta
I tried plugging the values into the gsinθ - ugcosθ = a equation, I assumed I could just get rid of the mass variables because they'll all cancel out anyways
gsinθ - ugcosθ = a = 9.8sin(36.8999 degrees) - .75(9.8)cos(36.8999 degrees)
the answer I got doesn't my teachers solution of 2.744
I'm think the part that's throwing me off is "this is the angle that the box starts sliding)
Hi alex_todd, Welcome to Physics Forums!
Once the box is moving, what type of friction applies?
