Finding an operation that makes a group
  • Context: Graduate
  • Thread starter Thread starter learningphysics
    Group
6 replies · 2K views
Homework Helper
Hi. I'm working through the book "Elements of Abstract Algebra" by Allan Clark. This question has stumped me... find an operation on (0,1) (set of reals x such that 0<x<1 ) that makes (0,1) a group and makes the inverse of x, 1-x.
I'd appreciate any help. Thanks.
Do you know of an operation on R that makes it into a group with -x the inverse of x? Think of a way to make (0,1) correspond to R such that you can define your operation on (0,1) in terms of the very familiar operation on R.
Another thing you might want to think about is what the identity of the group will be.
Thanks AKG and Nate. I believe I've found the answer but I'm not sure why the method I used "works"...
I looked for a way to make (0,1) correspond to R as AKG said. I used the function: [tex]\frac{1}{2}tanh(u) + \frac{1}{2}[/tex]
From here I decided to multiply out [tex]\frac{1}{2}tanh(u + v) + \frac{1}{2}[/tex]
Then after setting [tex]x = \frac{1}{2}tanh(u) + \frac{1}{2}[/tex] and [tex]y = \frac{1}{2}tanh(v) + \frac{1}{2}[/tex], I rewrote the above as:
[tex]\frac{xy}{1+2xy-x-y}[/tex] which is the product.
(I got this idea because the previous problem had the function [tex]\frac{x+y}{1+xy}[/tex] which you can get from substiting [tex]x=tanh(u)[/tex] and [tex]y=tanh(v)[/tex] into [tex]tanh(x+y)[/tex] but I really don't understand why it works)
Why did this method work? Thanks again for all your help.
Because the target of a group isomorphism is a group. You just constructed the isomorphism before you figured out what the group was.
that is a wonderful book. hang in there and you will learn a lot.
Thanks Hurkyl and mathwonk. The book hasn't covered group isomorphisms yet, but I looked it up and everything makes perfect sense.
