Finding Angular Velocity of a Torsion Spring Assembly
20 replies · 7K views · last reply
qweazy
When Θ=0, the assembly is held at rest, and the torsional spring is untwisted. If the assembly is released and falls downward, determine its angular velocity at the instant Θ=90°. Rod AB has a mass of 6kg, and disk has a mass of 9kg.
Rod is 450mm and disk has a radius of 75mm
So there is a pin holding the assembly upwards which is when Θ=0 and at the pin there is a torsional spring with constant of k=20N m/rad. One end of the rod is attached to the pin and the other is attached to the disk.
T1+∑U=T2
So first I found the center of mass of the combined mass
I called mass of the rod M and mass of disk m.
Center of mass = (.5(.45)6+(.45+.075)9)/(6+9)= .405m
Then I found the moment of inertia
I=(1/3)(6(.45)^2)+(3/2)(9)(.075)^2+9(.525)^2= 2.96
T1=0 since the assembly started from rest.
Then I found T2
.5mv^2+.5Iω^2
.5(M+m)(.405ω)^2+.5(2.96)ω^2=2.71ω^2
Solved for the potential energy of the spring
.5(20)(π/2)^2=24.674
solved for ∑U= mgh-24.674= 34.861
solved for ω
ω=3.59rad/s
actual answer: 4.9rad/s
What am I doing wrong?
Dont have a camera but I drew a picture :)
and the numbers are in mm
qweazy said:
T1+∑U=T2
You are assuming that [itex]\sum U[/itex] is 0 at the end. Is that true?
Ixx=Iyy=(1/4)mr^2
Izz=(1/2)mr^2
Iz'z'=(3/2)mr^2
This is what the book gives me
No, I'm assuming it equals mgh-1/2ks^2
I think its just saying that its rotating about that axis. Izz is rotating about the z axis and Ixx is rotating about the x-axis and so on
Yeah, I get that part. My question is what is the z'z' axis?
Not sure where the pin is but, based on your second diagram, you are not being consistent when applying the parallel axis theorem. I would take I about the z-z axis instead.
No, for I I got 2.91 and solved it like I how I did before and got 3.60rad/s
Ok, no surprise I guess.
Can you show your calc for mgh?
OK, I see your mistake now. Your kinetic energy included a translational term but all the kinetic energy here is rotational only. Try and see if this gives the right answer.
Yea I got it. Thanks a lot for helping me. I appreciate it.
