Finding Area of Graphs with x^2: A General Solution?
The discussion revolves around finding a point on the graph of the function \(y = x^2\) that divides the area under the curve from 0 to a point \(a\) into two equal parts. The focus is on the mathematical approach to determine this point, including the use of integrals.
  • One participant asks if there is a general solution for finding a point \(c\) such that the area to the left of \(c\) under the curve \(y = x^2\) is equal to the area to the right up to \(a\).
  • Another participant notes that the function \(f(x) = x^2\) is symmetric about the \(y\)-axis, implying that the areas from \([-a, 0]\) and \([0, a]\) are equal.
  • Some participants express confusion about what is meant by "the left side" and seek clarification on the specific areas being considered.
  • A participant proposes a mathematical relationship \(2/3 b^3 = 1/3 c^3\) based on their calculations, suggesting this might serve as a general solution.
  • Another participant agrees that for certain interpretations of the areas, the proposed relationship could work as a general solution.
  • One participant reiterates the need for a clearer statement of the problem to facilitate understanding and discussion.
Participants express varying levels of understanding and interpretation of the problem, leading to some confusion. There is no consensus on a clear general solution, and multiple interpretations of the areas involved remain present.
Some assumptions about the intervals and the specific areas being compared are not fully articulated, which may affect the clarity of the discussion.
Brage Eidsvik
Hello,
If I have an x^2 graph that goes from 0 to a point a. Is there a general solution to where the area of the left side is equal to the area of the right?
I do not fully understand your question I believe.
Because ##f(x) = x^2## is symmetric relative to the ##y##-axis, the area between the curve and the ##x##-axis in the interval ##[-a,0]## is equal to the area under the curve and the ##x##-axis in the interval ##[0,a]##
In integral terms:
##\int\limits_0^a x^2 dx = \int\limits_{-a}^{0} x^2 dx ##
On the left side of what?
With integrals that should be easy to do.
I want to cut the graph in two. And yeah, the integral of the left piece should be equal the integral of the right.
I think I solved it and got 2/3 b^3 = 1/3 c^3.
This is if I take the integral from 0 to c, then b will be the center. I was wondering if this works as a general solution?
For some interpretation of the areas you consider, that works as general solution.
It would be helpful if you stated the problem more clearly. Here is what I think you were trying to say.
Find a point in the interval [0, a] that divides the area under the graph of ##y = x^2## and above the x-axis into two equal parts. In other words, find c for with ##\int_0^c x^2 dx = \int_c^a x^2 dx##.​
  • · Replies 24 ·
