Finding Coordinates of Point P in Quadrant 2 with sin(-)=m
  • Thread starter Thread starter FalconF1
    Coordinates Point
To find the coordinates of point P in quadrant 2 where sin(-) = m, one must understand the properties of the unit circle. In this context, sin(theta) represents the y-coordinate, while cos(theta) represents the x-coordinate, with the radius of the unit circle being 1. For point P, the coordinates can be expressed as (x, y) = (cos(theta), sin(theta)), where y = m. Since P is in quadrant 2, the x-coordinate will be negative, leading to the coordinates of P being (-√(1 - m²), m). This illustrates the relationship between sine and cosine in determining the coordinates of points on the unit circle.
FalconF1
Point P is the intersection of the terminal arm of angle (-) in standard position and the unit circle with centre (0, 0). If P is in quadrant 2 and sin (-)= m, determine the coordinates of P in terms of m.
no idea
This is a lovely example of the special properties of the unit circle. The first thing you should do though with a problem like this is draw a picture.
http://img24.imageshack.us/my.php?image=tempw.jpg
FalconF1, what is the definition of sin \theta and cos \theta in a unit circle?
01
The definition of sin theta in any case is opposite/hypotenuse and cos theta is adjecent/hypotenuse. The unit circle has a radius of 1 so any right triangle with vertices at the origin, a point P on the circle, and the X or Y axis ( is a purely your choice, most choose the X axis ) will have a hypotenuse of 1. So if you chose to drop to the X axis then sin theta = Y/1 and cos theta = X/1.
My teacher used to say that the easiest way to remember sin theta is Y sin
  • · Replies 62 ·
10K
  • · Replies 52 ·
