Finding Current and B Field given J(p) in Z Direction
4 replies · 2K views
iontail
the current density is given by J(p) = (I/pi) * p^2 * e^(-p^2) in z direction
The question is to first show that the cureent flowing through the wire is 'I' and then to find then to find the B field.
stokes theorem.
integral of B.dl = I
I = J.dS
i can find the magnetic field. however i am stuck on the first part that requires me to proof the total current is I.
I set up the problem in cylindrical coordinates and tired the double integration between 0 to 2pi and o to a(arbitsry distance) however this does not give the correct result. plese point me in the right direction
Hi iontail,
iontail said:
the current density is given by J(p) = (I/pi) * p^2 * e^(-x^2) in z direction
stokes theorem.
I = J.dS
Can you verify your equation? You have:
Is that supposed to be p^2 in the exponential instead of x^2? Also, can you show your work for the integration?
sorry about that it is supposed to b p^2, a typo. I tried integrating by parts on the ,p, terms and using the cylindrical coordinates formula for for dS. I get e^-p(p+3) as result
I don't believe the integral should be cut off at an arbitrary limit (like you are doing with the quantity a); instead the radial varible p should be integrated from 0 to infinity. If you are still getting the wrong answer, please post the integration steps you are taking.
