Efficiently Finding Cycles in a Graph: A Scientific Exploration
The discussion focuses on efficiently finding cycles in a graph using algorithms like Depth First Search (DFS). The user is attempting to identify all basic cycles in a graph but struggles with the polynomial time complexity of their current method, which results in excessive recursive calls. They inquire about alternative approaches, including the potential use of Boruvka's algorithm to derive a minimum spanning tree and identify edges for a minimum hitting set. The conversation emphasizes the challenge of cycle detection in graph theory and seeks more efficient methodologies. Overall, the exploration highlights the complexities involved in graph algorithms and the quest for optimization.
wololo
Recursion, graphs, DFS
To try to solve this algorithm, I first need to find all the basic cycles in the Graph G. When I have these cycles, I can simply pick the smallest edge in each of them and add them to the set F, while removing duplicates, which is trivial. However, I can't figure out an algorithm that would give me all the cycles in polynomial time.
I tried using a modified Depth First Search recursive method that, when it reaches a node that has already been visited, backtracks until it reaches again to find the cycle. However, for a simple graph with 8 nodes and 14 links my method gets called more than 500 times... I tried using what is described here: http://stackoverflow.com/questions/546655/finding-all-cycles-in-graph/549312#549312
Am I thinking about this problem correctly? What approach other than finding the cycles could I use? Thanks
Could I simply use Boruvka's algorithm to get a minimum spanning tree and add these edges to F?
I think all the edges that are not in a maximum spanning tree wil give me the minimum hitting set.
