Finding displacement current in an AC capacitor circuit
The discussion revolves around finding the displacement current in an AC capacitor circuit, specifically focusing on a capacitor with parallel plates being charged by an alternating current (AC) source. Participants are exploring the relationship between displacement current and conduction current in this context.
  • Participants discuss differentiating the charge equation to find displacement current and question the applicability of the exponential charging equation in an AC context. There are inquiries about using electric flux equations and the choice of Gaussian surfaces for applying Gauss's theorem.
The discussion is active, with participants providing insights into the relationship between electric field, charge, and electric flux. Some have suggested that the electric field can be assumed uniform at any instant, while others are questioning the implications of changing charge on the electric field. There is no explicit consensus yet, but various lines of reasoning are being explored.
Participants are navigating the complexities of AC circuits and the implications of changing electric fields, with some expressing uncertainty about the assumptions being made regarding uniformity and constancy in the electric field.
Peter Andrews
A capacitor is made of two parallel plates of area A, separation d. It is being charged by an AC source. Show that the displacement current inside the capacitor is the same as the conduction current.
Idisp = ε(dΦE/dt)
Q = CV
C = Aε/d
Xc = 1/(2πƒC)
Q(t) CV(1-e-t/τ)
First of all, as it's an AC circuit so we won't be completely charging the capacitor, so I don't think we will use the exponential charging equation for a capacitor.
The displacement current can be obtained by differentiating Q=CV.
That gives (dQ/dt) = C(dV/dt). Assuming V = Vosin(2πft), we get a suitable expression for Id. This leads to a current answer. But of we want to use the electric flux equation then how can we do that?
What is the equation for electric flux in terms of charge Q?
Can use the Gauss theorem, qenclosed/ε = ∫E.ds (closed integral, I don't know how to insert that sign). But what Guassian surface to choose?
You can assume the electric field to be uniform. So, electric flux will be simply electric field*area. What is the relevant formula for electric field here?
But how can we assume electric field to be constant when the charge is changing? The electric field in a capacitor is σ/ε. σ arial charge density. If we use that, then:
Φ = A.E
= Q/ε
Now differentiating,
(dΦ/dt) = (DQ/dt)/ε
So ε(dΦ/dt) = (DQ/dt)
Hence Idisplacement is dq/dt following which I come back to the process given in my solution above. Is there no other way via which I can get the result, without having to apply dq/dt on capacitor?
Peter Andrews said:
Φ = A.E
= Q/ε
Right.
The field is changing but it is uniform at any instant.
cnh1995 said:
Right.
Exactly. Constant and uniform have different meanings, at least in fields.
That is why I immidiately changed it to 'uniform'.
  • · Replies 24 ·
