Finding distance that a pad is compressed after being dropped
The discussion revolves around calculating the compression of a foam-rubber pad after an egg, weighing 56.3 g, is dropped from a height of 11.9 m. The egg reaches a velocity of 15.28 m/s just before impact and is brought to a stop by the pad in 6.32 ms. The user initially attempts to apply the energy conservation equation EP (mgh) = 1/2 kx² but struggles due to the absence of the spring constant. The correct approach involves using kinematic equations to determine the compression distance of the pad.
  • Understanding of kinematic equations in physics
  • Basic knowledge of energy conservation principles
  • Familiarity with impulse and momentum concepts
  • Ability to perform calculations involving acceleration and time
  • Study the application of kinematic equations for motion under constant acceleration
  • Learn about impulse-momentum theorem and its applications
  • Explore energy conservation in elastic and inelastic collisions
  • Investigate the concept of spring constants and Hooke's Law
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of impact and material compression in real-world scenarios.
Greywolfe1982
An egg is dropped from a third-floor win-
dow and lands on a foam-rubber pad without
breaking.
The acceleration of gravity is 9.81 m/s2 .
If a 56.3 g egg falls 11.9 m from rest and the
7.29 cm thick foam pad stops it in 6.32 ms,
by how much is the pad compressed? Assume
constant upward acceleration as the egg com-
presses the foam-rubber pad. (Assume that
the potential energy that the egg gains while
the pad is being compressed is negligible.)
Answer in units of m.
I'm not quite sure. I was thinking EP (mgh) = 1/2 kx2, but you aren't given the spring constant.
I calculated that just before the egg hit the pad, its velocity was 15.28m/s. After this...I have no clue where to go.
I think you probably have to do something with the impulse that the pad delivers to the egg:
The egg hits the pad with some initial velocity and then is brought to a complete stop before most likely bouncing up a little bit.
This is essentially an acceleration in the upward direction. Then you can use the equations:
d(x)=v(int)t=1/2at^2
v(final)=v(int) + at
to solve for your two unknowns.
Hope this helps, sorry my equations are not that easy to read (d=delta)
I think my brain is fried after doing physics for a few hours straight...but your first equation doesn't seem to make sense to me.
Two equals signs? How would you solve for x?
haha sorry the second equals was supposed to be a plus. my bad. Yea solving for x would have been interesting.
Tried that, got an answer of .144854 m, but according to my online assignment page, that's wrong. Is there a problem in my math, or is that the wrong formula to use?
10K
17K
