Finding domain of function (need an explanation for 2 Qs)
The discussion focuses on finding the domain of a function involving a square root and solving the inequality x(x-5) > 0. The user initially misinterprets the conditions for the inequality, mistakenly stating that x must be greater than both 0 and 5. However, it is clarified that the correct interpretation is that both factors must be nonzero and have the same sign, leading to the domain being (-infinity, 0) ∪ (5, infinity). Additionally, for the second question regarding the square root, it is emphasized that the expression under the square root must be non-negative. Clear communication and adherence to forum rules regarding language are also highlighted.
iwantcalculus
Homework problem moved from a technical forum section
i need help with finding the domain for a function where there is a square root , here is the picture of such questions :
http://imgur.com/YcqadOe
please see the picture, there are two questions in it, 35 and 37
let's start with question 35, this is how i try to solve it :
x^2 - 5x > 0
x (x-5) >0
x>0 and x-5>0 so the other answer is x>5
what to do after getting x>0 and x>5, are they even right?the real answer is: (-infinity, 0)u(5,infinity)
pls help!
x^2 - 5x > 0
x (x-5) >0
You are correct.
You should re-think about what conditions x should satisfy for x(x-5) to be greater than 0.
x^2 - 5x > 0
x (x-5) >0
pls help!
Does "pls" mean "please"? Please avoid "text speak" here.
Anyway, ##x(x-5) > 0## does NOT imply that ##x>0## and ##x > 5##. (Note that if you know ##x > 5## you already know that ##x > 0##, so you don't need to list it as a separate condition.)
More precisely: the inequality ##x(x-5) > 0## means that both ##x## and ##x-5## are nonzero and have the same sign. They do not need to be > 0.
iwantcalculus said:
pls help!
As Ray points out, "textspeak" isn't permitted at this site.
From the forum rules (https://www.physicsforums.com/threads/physics-forums-global-guidelines.414380/):
Language:
All posts must be in English. Posts in other languages will be deleted. Pay reasonable attention to written English communication standards. This includes the use of proper grammatical structure, punctuation, capitalization, spacing, and spelling. In particular, "I" is capitalized, there's a space after (but not before) a comma, a period, and other punctuation. Multiple exclamation marks are also discouraged. SMS messaging shorthand ("text-message-speak"), such as using "u" for "you", "please" for "please", or "wanna" for "want to" is not acceptable.
Likes RJLiberator
For question #37, consider what must occur:
You cannot have a negative under the square root. So we know that p must be 0 or greater than 0.
Now, use that same philosophy and the condition to fully solve the problem.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
