Finding dV/dt in V=4*L^3 at t=0.1s
  • Context: Undergrad
  • Thread starter Thread starter Tymick
    Differentiation
The discussion revolves around finding the rate of change of volume (dV/dt) given the volume formula V=4*L^3 and the rate of change of length (dL/dt=10*t) at a specific time (t=0.1 seconds). The participants explore the application of the chain rule and the implications of missing initial conditions.
  • Mathematical reasoning, Technical explanation, Debate/contested
  • Some participants suggest using the chain rule to express dV/dt as dV/dL multiplied by dL/dt.
  • One participant calculates dV/dt as 120*L^2 but expresses uncertainty about obtaining a numerical solution without knowing L.
  • Another participant notes that without a specific length at a given time, a numerical solution cannot be determined.
  • There is a discussion about whether the answer can be expressed solely in terms of L, with some arguing that dV/dt should not be given in terms of L alone.
  • One participant reflects on the relationship between changes in V and time, suggesting that the change in V over the change in time could be simplified but acknowledges missing initial conditions.
  • Clarifications are made regarding the application of the chain rule, with some participants questioning whether the correct derivatives have been calculated.
Participants generally agree that the chain rule is necessary for solving the problem, but there is disagreement about whether a numerical solution can be obtained without additional information about L. The discussion remains unresolved regarding the final expression for dV/dt.
Participants note limitations due to the absence of initial length values, which affects the ability to derive a numerical solution. The discussion also highlights potential confusion regarding the differentiation process and the application of the chain rule.
Tymick
I'm having some trouble with the following question, it was on a test previously and I haven't been able to figure it out :/
Let V=4*L^3 cm^3, where dl/dt=10*t cm/s. Find dV/dt at t=0.1 second
Since V is a function of L.
What you can do is use the chain rule and say that
[tex]\frac{dV}{dt}=\frac{dV}{dL} \times \frac{dL}{dt}[/tex]
Right, following the chain rule I do get dv/dt=120*L^2, I tried before to get L in terms of t, via integration but of course that gives 5t^2+C whereas C would pose as a problem since I've no way of obtaining it, so I can't get a numerical solution I just get a solution in terms of L...
[tex]\frac{dV}{dt}=12L^2[/tex]
You don't need L in terms of t when they tell you that [itex]\frac{dL}{dt}=10t[/itex]
so then this question doesn't have a numerical solution, only one in terms of L?
Is that all the data presented in the question? you don't have the initial length or any length at a particular time?
that's about it, my first post states out the entire question, no initial values, at all...and thanks by the way.
Well without a length at any particular time, you can't find a numerical solution.
I would think that as you are given dl/dt and you can work out dv/dl and you are looking for dv/dt
dv/dl [12L^3] dL = 12L^2 dl/dt = 10t
dv/dl x dl/dt... the dl's cancel to leave dv/dt
Wouldn't that be the chain rule?
Perhaps u'v + v'u
or in this case v't + t'v
NO WAIT! So much simpler.
Look at it as...
the change in v over the change in time. The change in V is simply 12L^3 , so dv/dt = 12L^3 / dt ( it would seem something is missing as one is not sure the intial time, I would have to assume time began at zero and so dt would be 0.1 s,
thus dv/dt = 12L^3/0.1 = 120L^3 (I think).
eta: oh I missed he t=0.1 s
Isn't dv/dt the differential of v with respect to t? Then surely the answer shouldn't be given in 'L' Also you have worked out dv/dl not dv/dt
I think the chain rule is needed.
Yes that was a typo on my part.
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 17 ·
