Finding Eigenvalues and determine if there are invariant lines
The discussion revolves around finding the eigenvalues of the matrix mapping (2, -4; -3, 3) and determining invariant lines. The initial calculation yielded incorrect eigenvalues of -6 and 1, while the correct eigenvalues are -1 and 6. It is clarified that distinct eigenvalues correspond to independent eigenvectors, which define the invariant lines. The concept of eigenvalues is explained, emphasizing that they are associated with non-zero vectors that satisfy the equation Tv = λv. The thread concludes with a focus on understanding the relationship between eigenvalues and their corresponding eigenvectors.
Luscinia
Find the eigen values of the following mapping and determine if there are invariant lines.
(2 -4)
(-3 3) is the mapping.
det (L-λI)=0
L-λI=
(2-λ -4)
(-3 3-λ)
det(L-λI)=0=ac-bd=(3-λ)(2-λ)-12
.: (3-λ)(2-λ)=12
6-3λ-2λ+λ2 -12=0
λ2-5λ-6=0
λ=-6 and 1
but the answer is supposed to be -1 and 6.
Also, since there are 2 eigenvalues, I'm guessing that means that there are 2 invariant lines. How do we find these 2 invariant lines?
(2 -4)
det (L-λI)=0
L-λI=
(2-λ -4)
(-3 3-λ)
.: (3-λ)(2-λ)=12
6-3λ-2λ+λ2 -12=0
λ2-5λ-6=0
λ=-6 and 1
Now, \lambda^2 -5\lambda -6 =0 looks like the right equation. Now, you need to solve for \lambda. YOu can do this one of two (or both) ways: factor or use the quadratic formula. Using what you wrote would imply that (\lambda - (-6))(\lambda - 1)=\lambda^2 - 5\lambda -6, but this isn't true. Remember, in factorisation, the factors are of the form (\lambda - a) where a is the root.
Well, first, eigenvalues are numbers not lines so this is not true. I expect that you mean that the lines in the direction of the eigenvectors are invariant.
(2 -4)
det (L-λI)=0
L-λI=
(2-λ -4)
(-3 3-λ)
.: (3-λ)(2-λ)=12
6-3λ-2λ+λ2 -12=0
λ2-5λ-6=0
λ=-6 and 1
Yes, that's because -6 and 1 are incorrect. (-6)^2- 5(-6)- 6= 36+ 30- 6= 60, not 0. And (1)^2- 5(1)- 6= 1- 5- 6= -10, not 0. How did you get -6 and 1?
No reason to guess. Distinct eigenvalues correspond to independent eigenvectors and those give the two lines. Do you understand the definition of "eigenvalue"?
A number \lambda is an eigenvalue of an operator, T, if and only if there exist a non-zero vector, v, such that Tv= \lambda v. Saying that -1 is an eigenvalue means there is a vector
\begin{bmatrix}x \\ y \end{bmatrix}
so that
\begin{bmatrix}2 & -4 \\ -3 & 3\end{bmatrix}\begin{bmatrix}x \\ y\end{bmatrix}= \begin{bmatrix}-x \\ -y\end{bmatrix}
Multiplying on the left will give two equations for x and y. Of course x= y= 0 is a solution so there will be a non-zero solution only if those two equations are dependent and, in that case, there will be an infinite number of solutions- all vectors pointing in the same direction and so defining a line.
  • · Replies 40 ·
23K
  • · Replies 25 ·
